BigJimnyMeet 2024
Power steering fluid change
- Thank you received: 1755
13 Apr 2019 14:23 #206001
Replied by Lambert on topic Power steering fluid change
I thought that most power steering systems self bleed when turning to full lock and activating the bypass valve?
- Thank you received: 41
13 Apr 2019 16:43 #206009
by BGBrit
Replied by BGBrit on topic Power steering fluid change
Thanks for that. I used up the two litres I had and all works good as before, just a little darker in colour than in the bottle so I might buy another as you suggest and pour that in too. It's a simple enough job to do...
13 Apr 2019 16:44 #206010
by BGBrit
Perhaps but without experience I went for the safe option. Cheers.
16 Nov 2023 17:07 - 16 Nov 2023 17:11 #252160
by Atheling
Replied by Atheling on topic Power steering fluid change
Ok so thought I'd continue on this old thread as relevant.
Does the PAS reservoir cap come off - and how, unscrew, prise off? I can't budge it either way. Stressing the components - and me! Trying the syringe it out renewal using the filler plug but can only get 50mls or so because of obstructive filter. Take a long time that way.
2010 1.3 VVT Jimny.
2010 1.3 VVT Jimny.
Last edit: 16 Nov 2023 17:11 by Atheling.
- Thank you received: 650
16 Nov 2023 18:14 #252161
Replied by jackonlyjack on topic Power steering fluid change
Unscrews on my 04 plate
The following user(s) said Thank You: Atheling
17 Nov 2023 16:08 #252174
by Atheling
I'm beginning to think it's welded shut. I cannot shift it with various wrenches tools (jam jar lid remover even!), hot water, hammering rim, wd40. Removed from its brace to avoid breaking the bottle. Humiliation. Maybe 2010 model is different? Anyone confirm it opens on later gen 3s?
- rogerzilla
- Thank you received: 57
17 Nov 2023 18:48 #252177
by rogerzilla
Replied by rogerzilla on topic Power steering fluid change
Definitely comes off on a 2012 car
17 Nov 2023 19:14 #252178
by Atheling
Thanks chaps. Limp-wristedness then!
Time to create page: 0.140 seconds
