BigJimnyMeet 2024
Temporary/timed warning lights on dashboard
- Keirravn
- Visitor
03 Apr 2019 22:19 #205506
by Keirravn
I may get the meter out and see what I can find but it feels like maybe a lot of effort Vs the cost of a replacement cluster. Unless replacing it doesn't cure it of course
Replied by Keirravn on topic Temporary/timed warning lights on dashboard
What's an FSM?yakuza wrote: I measured the signals on the connectors into the cluster to find they were all there and correct before buying a new one..
It is all there in the FSM, but the wiring inside the cluster is more difficult to find.
- Thank you received: 1761
04 Apr 2019 04:20 #205509
Replied by Lambert on topic Temporary/timed warning lights on dashboard
Factory service manual. There are various sources on the internet but copyright precludes me from openly linking one.
The following user(s) said Thank You: Keirravn
- Thank you received: 332
04 Apr 2019 11:43 #205531
Replied by yakuza on topic Temporary/timed warning lights on dashboard
www.bigjimny.com/mediawiki/index.php/Workshop_manuals
Here is a list of them and some part numbers..
And then there is google.
And then there is different more or less illegal sites that might or might not be infested with virus.. Not recommended!
- Keirravn
- Visitor
05 Apr 2019 17:55 #205576
by Keirravn
Replied by Keirravn on topic Re:Temporary/timed warning lights on dashboard
Brilliant guys cheers for that
I'll investigate further once it's home
- Keirravn
- Visitor
03 Aug 2019 18:43 #211785
by Keirravn
So I replaced the instrument panel but still have no oil warning or EML
I’ve perused as many manual files as I can find but haven’t been able to find any details of wire colours going to the instrument panel.
My thinking is to maybe just wire up a new oil warning light on the dash somewhere and live without the EML
- Rob
- Visitor
23 Apr 2020 00:33 #221402
by Rob
Replied by Rob on topic Temporary/timed warning lights on dashboard
I have exactly the same problem. How did you resolve it?
- Keirravn
- Visitor
23 Apr 2020 08:23 #221411
by Keirravn
I haven't yet. I bought a new oil light which I'm going to wire directly to the switch at some point soon.
Because my car previously suffered a rat or mouse infestation There's a good chance there was a part chewed wire further behind the dash than I can easily see. I don't know if the oil light comes via the ECU or what so tracking it down vs wiring a new LED seems an easy choice in my case.
I would guess you've checked the bulbs? They're easy to get to. Checking the bulbs then testing the switch was my starting place. Because it's neither of these on mine it's more complicated - annoyingly
23 Apr 2020 10:55 #221416
My cluster was broken from disconnecting a Bluetooth adapter from the diagnose connector while the car was running. Stupid of course.
My brake warning light was on constantly and some of the others may have been out dunno. Changing the cluster helped.
But I was able to find the wires in the FSM and measure the signals going into the cluster. I could switch the ignition on without the cluster connected to measure at the connectors.
Time to create page: 0.143 seconds
