BigJimnyMeet 2024
Do I have the wobble, I am not sure
- Thank you received: 1755
21 Feb 2019 11:06 #203582
Replied by Lambert on topic Do I have the wobble, I am not sure
Everyone has to learn somewhere. Yes It's a diy job just a bit messy. That said if you're struggling to tell a spanner from a hammer then a garage shouldbe considered.
- Don76
- Visitor
21 Feb 2019 11:50 #203584
by Don76
Replied by Don76 on topic Do I have the wobble, I am not sure
Thanks lol
I think I will give it a go.
- Thank you received: 551
21 Feb 2019 12:37 - 21 Feb 2019 12:59 #203588
by Scimike
Replied by Scimike on topic Do I have the wobble, I am not sure
I am near Stoke, Kidsgrove to be precise. I need to do mine and have the parts and it's not a million miles different from my Land Rover which I have done many times. If you need any help just ask.
I can recommend JHL near Hanley, not Suzuki specific, but they have worked on my ex PoloTDI and I was very impressed with the work. As I generally do not like garages I will do all my own work on the Jimny, that's why I own it.
Mike
Mike
Last edit: 21 Feb 2019 12:59 by Scimike.
The following user(s) said Thank You: Don76
- Bulbus
- Visitor
21 Feb 2019 21:07 #203614
by Bulbus
Replied by Bulbus on topic Do I have the wobble, I am not sure
this is a great forum.....thats what my swivels look like....problem then...
- Max Headroom
- Banned
- Thank you received: 217
22 Feb 2019 03:23 #203635
by Max Headroom
Replied by Max Headroom on topic Do I have the wobble, I am not sure
Don, I reckon with some decent basic tools, you should be able to follow the excellent guide and do the job yourself.
Just be safe and make sure you have an axle-stand in position to protect you
- Don76
- Visitor
23 Feb 2019 19:20 #203726
by Don76
Thanks. I will be soaking everything in WD40 over the coming days to help with the dismantling on Wednesday
24 Feb 2019 06:04 #203743
by Bosanek
Replied by Bosanek on topic Do I have the wobble, I am not sure
The topic of the notorious, horrific and occult death wobble had been munched through so many times in the past. It has been demystified, debunked and systematically dissected a long time ago, and the collective wisdom has been engraved in this web site's wiki (look for the article in Wiki's FAQ section).
Whenever someone new asks something about the death wobble next time in the forum, it is best to skip the discussion and point them directly to the wiki article. In 99% of the cases, they will get their salvation there.
The only thing remaining to add to that death wobble universe is if Jimnys 4 also suffer from the same trait or not. I presume that they do. I am eager to see the first reports once someone bashes a Jimny 4 to a proper extent.
- Max Headroom
- Banned
24 Feb 2019 10:28 #203750
by Max Headroom
As I see it, I think the worry for those with no real knowledge of the death wobble per se is that they think that ANY wobble is death wobble whereas that is not the case; particularly with an unmodified vehicle. As I understand it It's simply more likely to be king pin bearings and/or bushes on say the panhard rod
24 Feb 2019 19:48 #203781
Also it's often the case that a new owner to Jimny is not unreasonably going to benefit from having their hand held metaphorically speaking when they first encounter steering wobble. We as seasoned users could be considered to have a degree of duty of care to newbies to gently guide them through this initial period of concern. Just dumping them with a tonne of scary sounding information while technically helpful can be a bit emotionally overwhelming.
- Don76
- Visitor
27 Feb 2019 22:23 #203910
by Don76
Drivers side done. ABS sensor bolt sheered offf so had to drill that out and tap it 6mm. Other than that and some very stubborn bolts it went ok.
Passenger side Friday.
28 Feb 2019 05:18 #203919
Nice one!
- Max Headroom
- Banned
28 Feb 2019 06:21 #203921
by Max Headroom
Well done!
Slow and steady and meticulously, always the best way
Time to create page: 0.144 seconds
