The dreaded 2005 gearbox issue!
- Harry N
- Visitor
Looking for a bit of advice as to how best to proceed?
I have a 2005 Jimny which has only done 50,00 miles and hasn't been thrashed.
I've developed a "ticking" in 3rd and 4th gear which after a bit of research I've realised is a recognized fault.
I've taken it to the main dealer and they have offered to fit a new gearbox and change the clutch for the princely sum of £3500 which I would guess is more than the value of the car!
What to do? Having looked on this website I don't have the technical ability to sort this myself!
Keep driving the car and hope for the best?
Look for a reconditioned or second hand box and get my local garage to swop it?
Find a gearbox specialist and see if they can repair the fault?
Spend £3500 and put it down to bad luck? (I've had to spend very little on the car since I bought it in 2010 so I guess I can't complain too much...)
Any thoughts or advice gratefully received!
- Thank you received: 584
If not, see if there is a specialist who will.
It is a fair amount of work getting the gearbox out, but replacing the bearings is easy, I'd have thought less than £1000 including the parts should do it, but I never pay anyone to do something I can do myself, so I don't have much of a handle on garage prices.
I'd look for a local gearbox specialist and speak to a few local independent mechanics. It's not a big job for people that work on cars and the good independent people normally charge more fairly than the garages full of less experienced 'technicians'.
- Max Headroom
- Banned
- Thank you received: 217
I drained mine and refilled it in March, and although I have no noises or problems yet, there was swarfe found on the mag-plug.
If thats the R72 gearbox, only a matter of weeks back I got a hypothetical quote for replacing the box on mine with MR Clutch . The Swindon branch changed my clutch a few weeks back for £250 which I thought wasn't bad as I neither have the time nor the facilities to undertake such a task
Obvioulsy you would probably want to consider doing a clutch cx at the same time while it's all apart
- Visitor
- Visitor
- paradox1001
- Visitor
I bet it will be a lot cheaper than you’ve been quoted.
Is it specific years that have gearbox problems?
- Max Headroom
- Banned
- OlaGB
- Visitor
paradox1001 wrote: Find yourself an independent gearbox specialist and get them to quote you.
Not sure what year, but at some point they changed from open bearings, to sealed bearings. I rebuilt my own box, and got only sealed bearings in the kit i bought. The seller sold tons of gearbox bearing kits, and said the sealed bearings where more expensive, but last longer and is used by many manufacurers stock as well.
Yakuza (member here) bought a low km 2013(?) box used, and inspected it with a small cam and found sealed bearings in it as well..
The bearing that dies first, seems to be the highest rear one. Probably not enough oil flow around it, or maybe the most loaded bearing, not sure.
I´m only 8k km down the road after rebuilding, so its too early to say anything about lifespan.
- Thank you received: 332
I think mine was 2012 or 2013.. A bit hard to say with nowegian jimnys, but i think i kept the vin somewhere.
I read somewhere that after 2009 there is an upgrade.
I am abusing mine now with m16a engine, but i think the low gears in the transfer box helps putting more of the torque over to that box.
I top up my gearbox oil every so often now as i got the leaky intermediate shaft as well. Could have been a factor with my old gearbox failing, not sure..
I got these sounds from the bearings in the box, and when they got a bit worse, the box had a total inner failure after 15-20km. If you have noises from the bearings just stop driving and get it fixed.
- paradox1001
- Visitor
Might be an idea for me to change the oil as a precaution
