radiator removal
- littletriple
- Visitor
NicBe wrote: Just removed mine today,
Drain fluid
Unbolt fan cowling 3 Bottom 2 top, remove bolts completely or they will fowl the fan when you lift it out
Remove top hose
Remove bottom hose
Unbolt rad, 2 10mm bolts at top sides of rad
Move cowl as far forward to engine as pos
Lift rad out, hand spin the fan as you lift to allow the bottom outlet space you'll see.
Takes longer to drain than remove
Is this with aircon?
- NicBe
- Visitor
- Thank you received: 332
But not without removing the radiator.
- rogerzilla
- Thank you received: 64
Removing the top radiator bolts and leaning it forward allows you a precious few mm extra space.
- rogerzilla
I can see the ATF hoses underneath and my guess is that a fair bit of fluid would be held up in the rad, so I don't fancy disconnecting them.
Might have to farm this one out to a neighbour mechanic!
I would do a careful spray of WD40 penetrating (the special one) on the bolts on day one (with a rag to stop spillage to the belts) and then trying to dismantle on day two..
