BigJimnyMeet 2024
× A place for more technical discussions. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Changing the kingpin/swivel bearings - questions
02 Jul 2018 13:16 #193923 by 2013gary
Hi all,
My Jimny has developed terrible death wobble so I'm in the middle of changing my kingpin bearings. I've disassembled everything, and cleaned as well as I can. I have a few questions before I start to put things back together though:
1. In Martin's video, when he replaces the axle oil seal, he uses the end of a rubber mallet. Is this necessary? Mine pushed in by hand and seems a tight fit and is sitting nice and flush. I noticed that there's a long, thin metal spring around inside circumference of the rubber seal, and I don't want to risk damaging this by hammering the seal in further if not necessary.
2. The article on the wiki says to pack the CV with grease, but not to overpack. How much is too much?
3. The article and video also say to fill the knuckle with 100ml grease. Please can someone confirm that by 'knuckle' they mean the cup on the end of the axle, as in the attached picture? Also what's a good way of measuring 100ml grease?
4. Also, I've attached a picture of the old bearings. Apart from being filthy they don't look too bad as they are in one piece. Could these still have been the cause of the death wobble?
Gary
02 Jul 2018 13:40 - 02 Jul 2018 13:42 #193924 by mlines
The grease is 100ml OVERALL, including inside the CV joint itself. So its very little. Clean out the CV and pack with grease as well as the new kingpin Bearings. Then smear the rest around the exterior of the ball including where the large seal sits.
A tub of grease is typically 400 to 500 ml depending on what you have bought so 100ml is around or just under a quarter.
Those bearings could easily have been the source of the issue.
You can often push the seal home with your fingers, I just wanted to make sure mine had gone in all the way
Last edit: 02 Jul 2018 13:42 by mlines.
  • Riccy
  • Riccy's Avatar
  • Banned
  • Banned
  • J999 MNY Bashing around Carlisle
02 Jul 2018 17:29 #193927 by Riccy
100ml should be about 100g, so nick off with the kitchen scales, spoon it into a bag on the scales and there you go ;-)
Those bearings pictured look about done. I bet the one on the left is from the bottom.
  • Dano0404
  • Visitor
  • Visitor
02 Jul 2018 20:12 #193934 by Dano0404
I’m about to tackle this with brakes and wheel bearings let me know how it goes.
03 Jul 2018 07:50 #193943 by 2013gary
Thanks Martin and Riccy for your replies. You're right Riccy, the one on the left is from the bottom. Apart from being dirty I didn't think they looked too bad, so I was wondering if maybe something else was causing the wobble. I'll know soon when it's all back together.
Dano, it's not a bad job just a bit messy. The video on this site is really helpful. The circlip was easy to remove with a £10 pair of external circlip pliers from Halfords, and I tapped the old bearing races out with a small cold chisel. The brakes practically do themselves during the job, as you have to remove the pads and discs to get to the hub. If mine still has the wobble then I will be changing the wheel bearings next, although I will probably take the hub to a garage and pay someone to press the old bearings out and new ones in.
Gary
  • Dano0404
  • Visitor
  • Visitor
03 Jul 2018 19:56 #193947 by Dano0404
I tackled one side to night along with wheel bearing and brakes. Quite a easy job faily time consuming though. I use a 0.25mm spacer to give the bearings more thrust.
Took for a test drive and has definitely improved still a bit of wobble will do the other side in a day or two.
04 Jul 2018 12:45 - 04 Jul 2018 12:47 #193958 by 2013gary
Just put mine back together and the wobble is still just as bad as it was before. I suppose the next step is to do the kingpins on the other side and see if that makes a difference. The seals are currently out of stock on the BigJimny store so I'll have to wait :(
Gary
Last edit: 04 Jul 2018 12:47 by 2013gary.
04 Jul 2018 14:13 #193959 by theoldseacaptain
I had a similar issue a few months ago - changed all kingpins without much improvement. In the end it was new brake discs that cured it!
Sadly jimny-less but still got the bug!
  • Dano0404
  • Visitor
  • Visitor
04 Jul 2018 21:34 #193973 by Dano0404
Done the other side to day still a very slight wobble but think I can live with it for now. The disk guard rubbed as well witch makes a hell of a noise the wheel brace was perfect for bending it back.
05 Jul 2018 08:02 #193992 by 2013gary
theoldseacaptain wrote: I had a similar issue a few months ago - changed all kingpins without much improvement. In the end it was new brake discs that cured it!
Brake discs are an easy and cheap fix, but from what I've read on here the brake discs only cause wobble under braking. Was that the case with yours, or did it wobble when you weren't braking?
Dano0404 wrote: Done the other side to day still a very slight wobble but think I can live with it for now. The disk guard rubbed as well witch makes a hell of a noise the wheel brace was perfect for bending it back.
I've had this problem after changing a track rod end, I must have moved the guard while swinging on the the top nut or something.
Gary
05 Jul 2018 10:51 #194000 by theoldseacaptain
Yes, mine wobbled all the time which led me to the Kingpin bearings first....
05 Jul 2018 10:55 - 05 Jul 2018 10:55 #194001 by 2013gary
Interesting to know, thanks. I've just ordered new track rod ends, which I plan to fit before getting the wheel alignment looked at. If that doesn't work then I'll try new brake discs.
Gary
Last edit: 05 Jul 2018 10:55 by 2013gary.
Powered by Kunena Forum
