AVM Locking wheel hubs
- Thank you received: 225
I should first mention that I wouldn't post pictures of most of my AVM hub measurement since they are identical to yours. That said, I measured (as well as I could) the dimension from the hub head mounting surface (on the hub) to the outer surface on the vacuum seal. It appears to be about 7mm. The dimension on the hub head that you show for the pocket depth from the lip is 12mm. The measurement from the lip to the mounting surface on the hub head is 4mm. Therefore from the mounting surface on the hub head to the surface in the recess that is making contact with something should be about 8mm. Even without a gasket, that should be a 1mm clearance. It should be slightly more with the gasket. Seems a little closer than I would design but it should work.
It would only take the hub nut (and vacuum seal) sitting a little proud for it to make contact with the hub head in the location you indicate. If anyone would like to double check my measurements (it was a little awkward) I would welcome the sanity check.
- Thank you received: 332
I'll try again tonight
- NineCherries
- Visitor
Pic taken from avm’s web site.
- kayjay
- Visitor
Although it does confirm the correct model for my 2006 Jimny is th 457
- kayjay
- Visitor
Here is the existing car side showing the inner dia (D) of 60mm and that it protrudes (C) 8.67mm from the flange.
The photos below show the AVM side that must fit onto the above. Dimension (A) 57.45mm is narrower than (D) by 2.55mm. Given that dimension (b) is 7.44mm and dimension (C) is 8.67mm, some 1.23mm longer, its obvious that the binding will occur in the area indicated.
As a test I used 1.25mm washers to space out the two parts and no binding occurs. If others agree that their Jimny hub dimensions (C and D) are as mine then my AVM hubs would not fit them either. If so then there must be errors in the manufacturing of my AVM457 hubs and I should return them.
Also I cannot see how the locking collars are ever going to work given that they break up when tightened.
- Thank you received: 584
They can't work, as those hubs have straight holes.
The conical washers are to fill up the conical holes that you haven't got. The head of the bolt stops on the flange, and the cone washer compresses into the hole, closing up the split in the washer .
- kayjay
- Visitor
- Thank you received: 1761
- NineCherries
- Visitor
- kayjay
- Visitor
- NineCherries
- Visitor
Anyway glad you got yours sorted, and I’m looking forward to hear how yours perform. Tyre x hubs were on my short list but I think I found a good deal on my reinforced avm hubs. Hopefully it works out for both of us
- kayjay
- Visitor
