BigJimnyMeet 2024
Clutch
- Visitor
10 Mar 2018 21:13 #190248
Replied by Daniel30 on topic Re:Clutch
Fair enough Tom, think Im just having one of those weeks
- Thank you received: 332
13 Mar 2018 14:18 - 13 Mar 2018 14:19 #190360
I got the LUK. It was the cheapest one on ebay at the time. I had to replace my VW T5 clutch the same time so I was trying to save some on the Jimny.
The VW T5 clutch, work included, cost me 20000,- NOK approximately 2200£.
If the flywheel had been bad it would have costed an additional 1100£
My LUK is smelly gong up hill and after changing i got the shakes at 2000rpm, probably caused by the three springs instead of the original four springs setup as you see in the Exedy picture. Otherwise works fine, doesn't slip. m16a and 235 tires and original gears.
Next time my gearbox or engine is out it will be changed.
Last edit: 13 Mar 2018 14:19 by yakuza.
The following user(s) said Thank You: Daniel30
- Visitor
13 Mar 2018 15:15 #190362
Replied by Daniel30 on topic Clutch
So what clutch will you be getting next time?
13 Mar 2018 16:20 #190364
13 Mar 2018 19:24 #190372
But no more three springs clutch because that is the 2000rpm vibration i think.
dunno, maybe a centerforce SJ413 / Samurai clutch i got. Looks like it should fit, i cannot find any difference.Daniel30 wrote: So what clutch will you be getting next time?
Time to create page: 0.101 seconds
