BigJimnyMeet 2024
Jimny -2003 3" lift and 195/80/15
- OllieNZ
- Visitor
16 Oct 2017 13:15 #185290
by OllieNZ
Replied by OllieNZ on topic Re:Jimny -2003 3" lift and 195/80/15
The Landover case is readily available for as little as £50 they come in the defender and discovery 1 and early 2 models here in the UK.
The Landcruiser cases are from either a 70 or 80 series model are harder to find and more expensive at least here in the UK.
Both cases have the outputs dropped on the right hand side, the same as the Jimny. The Landcruiser shares a virtually identical auto transmission with the Vitara, swap a vit bellhousing onto a Landcruiser auto/t case assy and all you need is any vit engine and custom cross member(s) to support the box.
You can also buy an adaptor and spud shaft to mount the Landover lt230 to the Toyota transmission.
- Millen
- Visitor
20 Oct 2017 05:14 - 20 Oct 2017 08:08 #185377
by Millen
Replied by Millen on topic Jimny -2003 3" lift and 195/80/15
Very nice information from all of you!
Now back to tyres for a while, and possibly some other things. : )
Is there any other options, like other brands, what do you use?
I've talked about the tires from Jimnybits already and those that I thought about getting should work on a standard Jimny but maybe not with snowchains. (195/80/15).
If I do modify much, like putting on body kit, other supspension, big wheels, engine swaps and so on I should probably do it all at once and then I could do a new registration of the vehicle because I might fail yearly inspection if I don't.
That kind of registration would cost at least 4500 SEK (450 euro) and if that does not include the noise test It's another 1500 SEK (150 euro).
I will look into this more, they even have given out a book to people who want to modify and do it by the books.
Keith's bodykit look smooth and well made thou so I think they would look past that at inspection easy if I mount my licence plate in the "right" way.
But there is still the EU-regulations that has worked it's way in but it might go through with modifications as body kit and higher suspension if I just put on standard tyre size anyway.
Have past inspection with wide tyres and also extra wide body kit several times before so it might be fine anyway.
Now, I hope to get some advice on what clutch to get. I know some different material compositions but what should I get for my Jimny?
Mine is slipping more and more so I need to get one very soon.
Last edit: 20 Oct 2017 08:08 by Millen.
21 Oct 2017 10:27 #185395
by kirkynut
Replied by kirkynut on topic Jimny -2003 3" lift and 195/80/15
I've not got one personally but I've read nothing but good things about the Exedey clutch. I think a few people on here have them.
- Millen
- Visitor
21 Oct 2017 14:11 #185400
by Millen
Has anyone laid their hands on the Exedy Safari Tuff clutch?
Worth the extra money possibly? From what I read in the shop it sounds promising and might be worth it.
www.bigjimny.com/store/clutch-kit-exedy.html
- Thank you received: 651
21 Oct 2017 14:24 #185401
Replied by jackonlyjack on topic Jimny -2003 3" lift and 195/80/15
Has a big price tag
When i got my exedy's yes i bought 2
one for now and a spare for later they where on offer
and i could of got 4 for less than 200
Jack
Jack
- Millen
- Visitor
21 Oct 2017 14:51 - 21 Oct 2017 15:02 #185402
by Millen
Hi Jack
Was it the Safari version you bought then or possibly the other clutch from Exedy in the bigjimny shop?
I was also thinking the extra pressure could be good if I decide to give the Jimny a little bit of turbo boost later.
Last edit: 21 Oct 2017 15:02 by Millen.
- OllieNZ
- Visitor
21 Oct 2017 15:11 #185403
by OllieNZ
Another vote for the exedy clutch. Mine held up to 235/75 tyres with stock gearing.
No idea about the Safari version, it sounds good with increased clamping force and improved construction. Cost wise it's about halfway between a paddle clutch and the standard exedy model.
Your call on that one really.
21 Oct 2017 17:06 #185405
Replied by jackonlyjack on topic Re:Jimny -2003 3" lift and 195/80/15
Just the standard version
23 Oct 2017 20:57 #185471
by Keithy
Replied by Keithy on topic Jimny -2003 3" lift and 195/80/15
I have a very heavy duty organic clutch to go in the 1.6 turbo when it gets put together....I got it as a replacement for the ceramic paddle clutch the turbo ate in 3 weeks....very poor tribology on the cover as it never marked the flywheel and ate 6mm from the cover......I got worried when I used the word tribology and the clutch specialist just stared at me.
Strangely the clutch currently in my car is the one I removed as it was slipping under boost.....I removed .5mm from the mating face of the cover and it never slipped again.
- Millen
- Visitor
24 Oct 2017 10:03 #185481
by Millen
Keith, what does "...marked the flywheel..." mean in this?
That's quite a bit anyway, especially 6 mm.
New word for me to, but aint a clutch specialist... yet. : )
I'm actually thinking about ordering the Excedy Safari Tuff clutch today, it is probably still in stock in the BJ shop as I was told it was yesterday, got a quick answer from Martin about that.
I'll also add this question which is in another thread here, to see if I can get any recommendations when it comes to this:
"Is it recommended to replace the clutch cable to while at it?
Clutch pedal has felt a bit heavy and the pedal has also had a very short distance of slip to bite, but it might just be because of how it's contructed and/or the wear of the clutch."
This time a workshop will be doing this replacement, would like to do it but at the moment I just want to get it rolling without this unwanted slip.
Need the car to because now I have strained my other ancle to and also some parts at the bridge and under the forefoot is dammaged.
Soon off to rehabilitating training, getting those feet working as I want them to again. : )
24 Oct 2017 13:20 #185484
by Keithy
Tribology basically means materials properties when rubbed together.....I kind of expected a manufacturer of clutches to know about such things.
The ceramic paddle removed 6mm of material from the cover and made no marks on the flywheel at all....not even polished it.
Get the Exedy it'll be fine.
I've changed my clutch cable twice......fine mud seems to ruin them......no amount of cleaning oiling etc helps
they are too expensive to keep buying so I'm going hydraulic.
The boys at work run a £6000 ap racing clutch on the race car......makes my playing seem like value for money Ollie!
- Millen
- Visitor
24 Oct 2017 14:07 - 24 Oct 2017 14:23 #185488
by Millen
Was going to change a headgasket and have a head ported once but ...
The only clutch I ever bought was a ~£1300 one from Spec and I have not yet put that engine back in the car after a complete overhaul, with a set of cheramic coated JE pistons(one type of coat for the top and one for the sides), Dbilas cam+harder springs, some raceware headbolts, layered metal headgasket and ported intakes in the head which also was planed and cc volume balanced. Raised the compression a bit to for those lower revs. Oh, and the intake was matched with the head to and had a what they called a bafflekit installed in the oil sump.
That included a metal ring welded on the oil pickup and also a wall with a one way hinged door to get right amouth of oil when cornering booth ways.
New bores, valve seats done, parts weighted, balanced separate and together, so it should be able to safely rev 7000 instead of 6000 max.
The 944 Turbo should probably have the S2 gearbox instead, don't think I will have much use of a 300 km/h topspeed and the 944 S2 has a different gear ratio in 5th.
Did this together with friends and there was some companies involved in machining and balancing to.
Some day ... :
www.garaget.org/?car=32910
Will do that with some help later, now I need to get going with "St Jimny" and who knows what this will lead to. : D
I'll order a new cable to, probably worth to do. Thanks
Some day ... :
Last edit: 24 Oct 2017 14:23 by Millen.
Time to create page: 0.131 seconds
