Sand rat
- Wokka
- Visitor
Red rocket/radio flyer (still can't decide on a name yet) will be set up as more of a mini overland truck, something that allows me to get out into the desert over the weekend where I can chill out by a fire with a nice bottle of scotch, my dog, and whatever can I decide to bring for food.
Current direction:
2" suspension lift- done
Steering stabilizer - done
2"body lift - not yet, but ordering this week
Spacers/large offset rims - done 15x7 +45mm total
High clearance front bumper - done
Awning - done
Drawer - will knock up this weekend
Under roof high storage - will play with it this weekend
Dog barrier - will bolt between the drawer and roof box
275/70 r15 ish tires - once drive train mods are done the wider and softer, the better
Kaiser front and rear lockers - ordering this week
Now the tricky part,
# Do I keep the 27k m13aa motor currently in there and go for the jimnybits hi/low reduction box, or do I keep a lookout for an m15a/m16a and keep stock gearing
# Load index requirements on the tires are pretty low compared to most 4x4s. I realise that load index and a soft sidewall don't necessarily always go hand in hand, but for maximum flotation on sand I need the soft sidewall. Has anyone come across a lovely soft sidewalled tyre? Preferably in HT or even passenger car tread. AT's tend to be a little too diggy for low powered cars on the soft stuff
# desert runs so far have shown she is happiest in low range, gears 2, 3, and 4
# finally, speed limits out here top out at 140km/h, while I don't need to hit that speed, I'd prefer not to be a speed bump in traffic, she currently is comfortable at 110, I'd like to keep that capability at least
Shiny side up
- Thank you received: 1759
I'd think about a 1" body lift instead of a 2" one as less needs changing but I know an inch makes all the difference to us blokes!
The Kaiser diff in the front might be a pain! Not on sand but on any other surface that's not quite as loose that you want 4x4 for. The cv's are weak don't forget, what with that bigger engine too.
Perhaps put the money from the from Kaiser towards hardened cv's and front shafts and then if you think you need a locker in the front in the future you could save for an arb.
Now its all different for green lanes, but will still sit happily enough at 60mph (just under 100kph). it will do 80 but is screaming on the revs and drinks fuel.
The bigger engine makes it much more useable, as said above. if taking it easy its no worse on fuel than many standard jimnys. Aerodynamics are bad so things like a roof rack/tent really drag it down.
- Wokka
- Visitor
I've gone with the rear only for now, along with the 2" lift to give me a range of tyres up to 30" ish.
Speaking to a couple of local tuner guys, on the slow hunt for a swift sport half cut for the doner engine, but the beating my bank balance has taken in the last week means it might be a slow search
At 30p a litre, I'm not really fussed about fuel economy.
- Wokka
- Visitor
Lock rites use an elliptical cam arrangement to force teeth to lock whenever speeds between the driveline and diffs are different (under acceleration or engine braking.
Kaiser, even when locked will allow a wheel to freewheel, as long as it does not turn slower than the driven wheel
Wokka wrote: Interested why you think so.
Both drive the slowest wheel and allow the faster wheel to freewheel. A properly setup lockright does not lock both wheels under acceleration. As one wheel turns faster, pressure is taken off that side gear allowing the teeth to overrun (characteristic click click noise when turning).
It might be that Kaiser diffs are easier to setup and more reliable in their operation, but in a perfect world both would perform exactly the same.
- Wokka
- Visitor
- Wokka
- Visitor
I'm going to drive some stakes into soft sand to mark the current open diff turning circle on sand, then try it with the lockers installed to see if there is any push
