trail gear electronic t case reduction kit ?
- Thank you received: 332
I find the job and switch from electric t-case to rocklobster not so tempting unless you are going for bigger than 31" tires as riccy says. the gearing will be way off in high range unless you change diffs and/or gearbox as well. by changing the gearbox you will not have to make your own driveshaft, and you will get a weak link R72 out of the car though..
it is also possible to change the low range wheels only inside the jimny electric T-case and although pricey they are way more tempting for those of us with M16 engine that use the car mainly on highway and with 235-75-15 tires only.
See also post below where i gathered some info on the low range only electric t-case options:
www.bigjimny.com/index.php/forum?view=topic&catid=7&id=62051
Trail gear doesn't even know, i asked them..
I have no understanding what this percentage means to me at all. Is it the change in the ratio of the box itself or the crawl ratio?
I do not even want to know, just tell me the ratio!
- TomDK
- Visitor
The real ratio of the 87% reduction gearset is 4.16:1 in low range and around 1.5:1 in high range.
TomDK wrote: What ratio is it you want to know?
ok, thanks!
For me going from 1.0 to 1.5 in high gear ratio sounds like 50%.. Would make the car unusable onroad..
So no point in this kit for me..
Sure this is correct? push button transfers got 1.0/2.0 in high/low range.
please show me the maths for the percentage calculations, i still do not understand
the 70% gears have a 3.7:1 ratio.
- Thank you received: 225
A little before this original post, I had also been looking for this information. First I asked lowrange offroad and then I went directly to Trail-Gear. My results had been the same as the others (no reply). I have noticed now that Trail-Gear has clarified their ad showing that the reductions were based on the transfer box in a manual Jimny (1:1 H and 2.002:1 L). They list the reduced ratios as 1.17:1 and 3.74:1.
Mostly now, I'm waiting to see what www.protrack.gr comes up with. According to an email from Michael Theologitis at Protrack, they are currently working on gear sets with several reduction options.
Did you get any info on how long before products are for sale?
I have been saving up to buy low gears so I was almost ready to buy these now.
I was at first thinking about buying the low gear option only.
Having 235's and m16a I like my current rpm in high range on highway.
The low gear only gear set was out of stock for a long time, and now that product is no longer available.
So i am back to this set now. I guess i can use the low gears only and keep the high range for later swap if i cut my arches and buy bigger wheels in the future.
This is most of the text in the email I received:
We are manufacturer.
And we are the first to design and test reduction gears for low and High and for all jimny models.
In last months, these products have been copied from another manufacturer and after that the result is many sales of wrong components for car and we having many questions like yours.
In any case, we can supply the right gears for all models.
And something just for your information.
The electronic Tcase for the automatic (1.32 H) uses a weak chain as the old (with lever) Tcase.
This period we have for testing some new sets of gears with a new stronger chain, and some more options in ratios for High and for Low.
I know that Protrack offered 17% high, 87% low reduction gears in the past but they are no longer on their site. I'm thinking they are probably going to go with gear sets that use the heavier transfer chain from the diesel Jimny now. Just my speculation.
You probably already know but if you are looking for reduction in low range only, those sets already exist. APIO make them. The Zeal brand also used to be available from www.4x4prostaff.com although I have no idea how to negotiate their site.
Way too pricey when there is alternatives readily available elsewhere.
www.auszookers.com/forum/viewtopic.php?f=17&t=49478
Link above to a guy doing the low gears on his push button transfer.
Also some info on how he ordered the wheels from japan through a company that probably speaks japanese.
Drifting guys in Europe use different similar companies to order car parts from japan as well. But price for this probably makes it best to order from greece, protrack or jimnybits.
this page: global.rakuten.com/en/ is also possible to use, some kind of japanese ebay i think, but i have no experience there what so ever.
We working to build a new web site and the old is not supported any more.
The only infos that i know till now is the new prices.
For all versions for VVT with the factory chain, the new price is 650 euro.
For the new ratios included a new chain the estimation is +240 euro.
The prices above is without taxes.
Sor the shipping cost, please tell me your country.
Regards,
Michael Theologitis
I believe this means that the original gear sets on his homepage are available for 650 Euro and the newer ones are still in development.
- OlaGB
- Visitor
I also considered waiting for this, but ended up ordering the 87% TG kit instead. Should be plenty low enough for my kind of offroading, and if i get bothered with too low high gears, i bet theres alot of pre vvt owners willing to swap diff's.
My calculations gives me around 150rpm higher at 90km/h on 235/75-15 and the TG kit, compared to stock gear on stock wheels. I'm fine with that, as the car sucks above 100km/h, and is underpowered no matter what M16 motor i swap in there i guess..
