BigJimnyMeet 2024
R72 to R7ME gearbox swap question
- Venter
- Visitor
28 Apr 2018 15:51 #192252
by Venter
What are you going to seal it with (resin spec, etc)?
Replied by Venter on topic Re:R72 to R7ME gearbox swap question
Riccy wrote:
mlines wrote: Have you sealed the cap inside the prop flange?
Not yet,
that is the first thing i will try. Its in bits for welding, when time allows i will try that
28 Apr 2018 16:35 #192253
Replied by Riccy on topic Re:R72 to R7ME gearbox swap question
Arldite
tried superglue on the last one i had with the same problem but that didnt work.
Im thinking 2pac resin type stuff, so a good clean and then some arldite glue stuff will hopefully get me going again.
unless anyone has a better suggestion?
- Venter
- Visitor
28 Apr 2018 17:11 #192255
by Venter
Replied by Venter on topic R72 to R7ME gearbox swap question
Cheers
Just been looking into it, and reckon I'll go for this stuff (unless anyone has doubts...)
www.amazon.co.uk/gp/product/B005O0366Q/r...&smid=A28CP5FJLXYWDR
29 Apr 2018 06:18 #192263
Replied by Riccy on topic R72 to R7ME gearbox swap question
Cheers Venter, that stuff looks good.
BTW... you can remove the intermediate prop without draining the gearbox oil if the rear of the car is on ramps (or at least 20cm higher than the front). Dont just pull it out on the level as you will get covered in gearbox oil. So says the voice of experience
- Venter
- Visitor
29 Apr 2018 10:12 #192267
by Venter
Haha, thanks for the heads-up. I doubt that would be as much fun as it sounds!
Riccy wrote: Dont just pull it out on the level as you will get covered in gearbox oil. So says the voice of experience
- YangMan
- Visitor
09 Jun 2018 07:20 - 09 Jun 2018 07:21 #193319
by YangMan
Replied by YangMan on topic R72 to R7ME gearbox swap question
Hi am new to the forum
Am wondering how can the reverse switch be modified from r72 to r7me gearbox? Is there an adapter available online or what can I do to ensure the reverse light worked after doing the swap. Thanks
Last edit: 09 Jun 2018 07:21 by YangMan. Reason: Typo error
09 Jun 2018 11:20 #193330
it should just plug in, pretty sure the connector was the same or easy to adapt to.
- Thank you received: 252
10 Jun 2018 13:37 #193346
by j999pre
Grey pick up Jimny
Replied by j999pre on topic R72 to R7ME gearbox swap question
The reverse switch on the r7me has wires with a white plug on the end. I cut that off and the same on the Jimny harness and got a pair of built connectors to connect both sets of wires together
Grey pick up Jimny
Time to create page: 0.121 seconds
