BigJimnyMeet 2024
Headlight adjustment
- Thank you received: 18
16 Jun 2017 09:15 #182092
by 2013gary
Gary
Headlight adjustment was created by 2013gary
Hi,
My Jimny failed it's MOT last week because both of the headlight aims were too low. The tester said he tried to adjust them but was unable to as the adjusters didn't work.
So I took it home, parked next to a wall and fiddled around with the two adjuster bolts on the back of each healight until I thought I had solved it.
Took the car back for a retest today and the headlight aims are still too low.
Do the adjuster mechanisms ever fail, and is there a way to fix them? Replacing the headlights seems a bit drastic.
Gary
- Visitor
16 Jun 2017 19:14 - 16 Jun 2017 19:16 #182116
Replied by Daniel30 on topic Headlight adjustment
What reg is it ? Mine has a headlight adjustment on the right of the steering wheel
Last edit: 16 Jun 2017 19:16 by Daniel30.
- Thank you received: 1761
17 Jun 2017 05:45 #182125
Replied by Lambert on topic Headlight adjustment
Also check the bulbs are seated correctly in the reflectors, they should only go in one way but that doesn't mean they haven't been forced in wrong.
17 Jun 2017 06:41 #182129
by 2013gary
Gary
Replied by 2013gary on topic Headlight adjustment
Thanks for the helpful replies. I have owned this Jimny for 3 years and have never noticed the adjuster on the right of the steering wheel!
So what are the two adjuster bolts on the back of each headlight for?
I will also check the bulbs are seated correctly just to be sure (although they should be because I put them in)
Gary
17 Jun 2017 06:46 #182131
by Keithy
Replied by Keithy on topic Headlight adjustment
If the bulb was in wrong the pattern would be wrong......so did the adjuster in the car work?
The one on the headlight is a limiter I believe
18 Jun 2017 04:35 #182149
by 2013gary
Gary
The adjuster in the car seemed to work - the beam moves up and down. I won't know for sure until they test it again with the alignment device. As the MOT bloke tried to adjust the headlights during the test I'd have thought that he would have looked inside for a switch.
There are two bolts on the headlight itself. One at the top and one at the bottom. The ones on top didn't appear to do anything at all
Gary
- 1066Boy
- Visitor
18 Jun 2017 06:36 #182150
by 1066Boy
Replied by 1066Boy on topic Headlight adjustment
Normally on headlights, if you have 2 adjusters one is up/down adjustment & the other is left/right.
If you are turning one and it seams to make no difference its probly the left/right one. It only changes
the angle a little in this direction. I have not looked at the Jimny ones but this has been the case on
other vehicles that I have owned. Hope that is of some help.
18 Jun 2017 10:47 #182156
by 2013gary
Gary
Thanks for the info. So just to confirm the interior switch which moves the beam up and down according to the load in the car - would this affect the aim for the MOT? I've moved the beam upwards with it but don't want to look stupid by taking it back for the third time and still failing
Thanks
Thanks
Gary
- Visitor
18 Jun 2017 12:24 #182157
What did they say to the angle of the light when they failed it ? Was it too high ?
- 1066Boy
- Visitor
18 Jun 2017 13:47 #182158
by 1066Boy
With the switch on 0 the lights should be in normal position for everyday use + MOT.
the other settings lower the beam when you have a heavy load in the back so the lights don't
dazzle other road users.
18 Jun 2017 15:16 #182159
by 2013gary
Gary
They said it was too low.
I can't say for sure because I didn't look at the switch before I fiddled with it yesterday but I'm pretty sure it wasn't on 0 during the test. Could that be all the problem is then?
Judging by what Allan is saying it seems to make sense. I'd have thought the MOT man would have looked for the switch inside the car though as he was keen to sort it out so he didn't have to fail it.
Allan did you manage to get to Crowborough in the end?
Gary
- 1066Boy
- Visitor
18 Jun 2017 15:34 #182161
by 1066Boy
If the switch was not on 0 it would be to low for the test. I am not sure but the tester is not to adjust things during the test but many will, just depends on the day. Its like when they fail it for washers not working and all it needs is a bit of water.
I have a mate that tests mine so he will cut me a little slack. As for your other question, yes just added a YouTube vid.
Time to create page: 0.171 seconds
