BigJimnyMeet 2024
Re:Front Fog Lights
30 Jan 2019 13:39 #202098
by Bosanek
Replied by Bosanek on topic Front Fog Lights
Does anyone know how the front fog lamps attach to the 3rd gen. front bumper (used on Jimnys 2012-2018)?
I know that on the two earlier front bumper models, the front fog lamps do not attach directly to the bumper. Instead you need special metal brackets (which are different for 1st gen. and for 2nd gen. front bumper) onto which you mount the fog lamps, and then the entire assembly screws onto the predefined mounting points on the bumper. So the brackets are the ones which mount to the bumper.
However, I read somewhere that the 3rd gen front bumper has integrated plastic fog lamp brackets in it, so you just need to screw fog lamps directly onto the bumper. Can anyone confirm this?
22 May 2019 14:12 #208665
by Bosanek
I am planning to visit a dead Jimny in a vehicle junkyard in order to remove the wiring for the front fog lamp from it.
The Jimny was made in 2010, with 2nd gen, front bumper.
Does anyone know where the wiring for the fog lamps in the engine bay goes to, and where the wiring for the switch in the cabin goes to?
I need to get prepared before I go there, as they won't give me too much time to fiddle with the car.
- Thank you received: 1761
22 May 2019 14:22 #208667
Replied by Lambert on topic Front Fog Lights
Sorry I haven't had to take mine apart to that degree so I don't know the wiring location.
The following user(s) said Thank You: stiffsteve204me
22 May 2019 15:11 #208684
by RainerK
Replied by RainerK on topic Re:Front Fog Lights
The wiring for the front fog lights ends behind the headlights and is a cable not plugged into anything. I spotted mine easily.
The Gen3 front bumpers have the fog light attachment points already there.
I do not know where the fog light cables end in the dashboard. I would expect that they end directly behind the place, where the switch would go.
23 May 2019 11:23 #208792
by Bosanek
I had removed the front bumper from my car (built in 2013) and I could not find any wiring behind it.
Should I then remove the front headlamps to see if an unused cable is behind?
Is there a risk of disturbing the balance of the headlamps when demounting them?
- Jim Jim
- Visitor
23 May 2019 12:03 #208794
by Jim Jim
Replied by Jim Jim on topic Front Fog Lights
- Jim Jim
- Visitor
23 May 2019 16:10 #208817
by Jim Jim
24 May 2019 09:32 #208865
by RainerK
- Jim Jim
- Visitor
24 May 2019 13:17 #208873
by Jim Jim
Replied by Jim Jim on topic Re:Front Fog Lights
My Gimny is a 1999 gen 3, not too sure if they had self leveling lights then.
I checked my signal harness, it does not have that connector either but has the connector for the switch.
Cheers.
Cheers.
- Jim Jim
- Visitor
26 May 2019 13:01 #209011
by Jim Jim
I ordered this from the US, should be here by next Wednesday.
www.amazon.com/gp/product/B001KVM2QS/ref...le_s00?ie=UTF8&psc=1
Will install and see how it works. It comes with 55 watts halogen bulbs which i will replace with LED bulbs.
Cheers.
Cheers.
Time to create page: 0.157 seconds
