BigJimnyMeet 2024
× A place for more technical discussions. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
really loud vibration with slight judder
  • kelky7777
  • Visitor
  • Visitor
27 Jun 2017 02:36 #182314 by kelky7777
Replied by kelky7777 on topic really loud vibration with slight judder
I checked and yes the woo woo has also decreased to barley perceptible. Basically it seems any weakness in the drive gear, mounts, or anything else contribute to noise.
  • kelky7777
  • Visitor
  • Visitor
30 Jun 2017 18:27 #182403 by kelky7777
I noticed the 2 mounts that support the transfer case look a bit rotten, see pics, I'll replace those next and see if there is more improvement.
  • kelky7777
  • Visitor
  • Visitor
30 Jun 2017 18:48 - 30 Jun 2017 18:49 #182404 by kelky7777
I had the hubs off the other day and they look fine, no wear or water. I had a good look at all the vacuum pipes and nothing obvious there. Checked the appropriate fuse under the dash. Maybe an electrical problem? This is regarding my other problem, 4x4 not working as the hubs aren't engaging.
Last edit: 30 Jun 2017 18:49 by kelky7777.
30 Jun 2017 21:44 #182409 by Keithy
Does the square metal backing contact the metal on the transfer mounts....makes a strange noise on accel?
04 Jul 2017 14:56 #182462 by Halford
kelky7777 wrote: I had the hubs off the other day and they look fine, no wear or water. I had a good look at all the vacuum pipes and nothing obvious there. Checked the appropriate fuse under the dash. Maybe an electrical problem? This is regarding my other problem, 4x4 not working as the hubs aren't engaging.
did you make sure the hubs were totally clicked back into the hub housing
and check the splines on the ends of the shafts ?
not long ago when my vac system was failing, one of the hubs wasn't quite disengaging and it gave a similar noise as it chewed the ends on the spline on the shaft.
hope this helps
  • kelky7777
  • Visitor
  • Visitor
06 Jul 2017 10:44 #182509 by kelky7777
Before I fitted a new gearbox mount I would get a high pitch whine on acceleration, the noise disappeared after fitting the mount
07 Jul 2017 14:31 #182534 by helijohn
Halford wrote: ;)
Aha, another photobucket victim.
Do it right - use Hammerite
When the blue light is flashing I am kidding.
  • kelky7777
  • Visitor
  • Visitor
08 Jul 2017 01:53 #182541 by kelky7777
hope this helps
I didn't really check for that, I'll take the hubs off again and check, though with 4x4 engaged with engine running in neutral I did the check where you jack one side at the front and check for lock, then the other side and both wheels free spinning without any resistance or noise, while the front prop is locked as it should be.
The flashing 4x4 light, which is on in my current jimny, isn't that reliable as a sign of vacuum fault as this was flashing on my last jimny yet the 4x4 worked fine. I would have liked to sort it out rather than manual hubs but I'm starting to think it's an electrical fault and perhaps too complicated.
  • kelky7777
  • Visitor
  • Visitor
08 Jul 2017 01:54 #182542 by kelky7777
helijohn wrote:
Halford wrote: ;)
Oh No! ... what's a photobucket victim?
08 Jul 2017 06:53 #182543 by helijohn
kelky7777 wrote: I would have liked to sort it out rather than manual hubs .
At the end of the day I always think the manual hub is the way to go.
08 Jul 2017 11:10 #182544 by mlines
kelky7777 wrote:
helijohn wrote:
Halford wrote: ;)
Photobucket has turned to a pay site. If you do not pay and your account is popular (views above a certain limit) you are cut off.
08 Jul 2017 13:43 #182545 by helijohn
mlines wrote:
kelky7777 wrote:
helijohn wrote:
Halford wrote: ;)
And I have threads all over the ether with loads of pics. Maybe the worst hit of mine is the POCUK site where my Pajero threads have now lost the lot but hey, that site refused to use its own hosting despite my moaning about it so it is divine retribution in a way.
Powered by Kunena Forum
