BigJimnyMeet 2024
× A place for more technical discussions. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Jimny "Hiccups" in Idle
19 Feb 2016 09:58 - 19 Feb 2016 10:00 #162668 by facade
Replied by facade on topic Jimny "Hiccups" in Idle
facade wrote: if you have tried it it is the best magic fluid ever.
Told you so B)
Last edit: 19 Feb 2016 10:00 by facade.
The following user(s) said Thank You: Adama
19 Feb 2016 10:20 #162672 by Busta
Replied by Busta on topic Jimny "Hiccups" in Idle
Sounds like you had dirty injectors then. Glad you got it sorted.
  • Adama
  • Visitor
  • Visitor
19 Feb 2016 10:55 #162674 by Adama
Replied by Adama on topic Jimny "Hiccups" in Idle
Dirty injectors clogged fuel pump who knows?
It is a magic fluid , now every 6 months I shall pour this stuff !
19 Feb 2016 12:41 #162676 by Busta
Clogged injectors are the only thing* on the fuel side that would affect the idle without causing big issues at higher engine speeds. If the fuel pump or anything else was clogged up it would initially cause issues at high rpms, where fuel and air flow are highest.
Magic is always a good way to fix things though. Which magic fuel additive would fix my kingpin bearings?
*maybe exhaust sensors too? Does this potion fix them?
19 Feb 2016 13:29 #162678 by facade
Busta wrote: *maybe exhaust sensors too? Does this potion fix them?
Supposed to, it is a concentrated detergent (polyether-amine en.wikipedia.org/wiki/Techron ) , like paying the extra for V-power or similar but all at once.
Actually, I've sent off for a can :ohmy: see if it can fix mine.
Remember that magic fluid they used to advertise on the TV, that would sharpen and set the blades on completely worn out hacksaw blades, just by dipping them in? I always wanted some.........
  • Adama
  • Visitor
  • Visitor
19 Feb 2016 15:31 #162679 by Adama
I can only recommend the BG 44k.
I am VERY sceptic when it comes to these additives and only after a long research I decided to try it.
It worked like magic.
As I understand it cleans up the fuel system.
I cannot recommend anything else sorry.
But I do suggest to try it if you have a hard idle.
19 Feb 2016 15:50 #162682 by facade
Adama wrote: I can only recommend the BG 44k.
I was serious, I've sent off for some. Mine has done over 100,000 miles, mainly on supermarket petrol, and I have heard great things of BG44K, like I said, everyone who has tried it says it is brilliant, but at nearly £20 a can, it is expensive to just pour in on the off chance it will do something. (But if I had just spent £20 on magic fluid, likely I'd notice a difference too ;) )
Trouble is, all that carbon will drop off and end up in the catalyst :S
19 Feb 2016 19:54 #162687 by Rhinoman
Replied by Rhinoman on topic Jimny "Hiccups" in Idle
The ECU flicks the EGR open for a moment to check for a change in manifold pressure which indicates that its working, if the EGR is sticky then you will get more of a dip but its not really an issue.
27 Feb 2016 14:40 #163045 by facade
As a follow up, I traded my cow for a tin of magic fluid (BG44k)
I excitedly put half of it in, (as it does 75 litres, and I've only got about 20) and went for a run @3500 rpm for 25 miles.
Made no difference whatsoever :(
I want my cow back :)
  • Daniel30
  • Visitor
  • Visitor
27 Feb 2016 15:05 #163046 by Daniel30
Replied by Daniel30 on topic Jimny "Hiccups" in Idle
PANTS!! No golden egg for you :silly: :blink: :)
27 Feb 2016 15:21 #163047 by Busta
That's unfortunate Facade. Magic stuff isn't cheap!
  • Adama
  • Visitor
  • Visitor
27 Feb 2016 15:25 #163049 by Adama
Too bad
But why not according to the instructions?
Full gas tank with a full bottle.
For me it did wonders.
Time to create page: 0.153 seconds
Powered by Kunena Forum
