BigJimnyMeet 2024
Changing the antifreeze/coolant
- Graphite675
- Visitor
12 Nov 2015 17:18 #156118
by Graphite675
Changing the antifreeze/coolant was created by Graphite675
Hi Guys,
Just a bit of advice please.
To change the antifreeze/coolant, is it just a case of taking out the drain plug at the bottom of the radiator??
If so does the drain plug require a new washer or anything before screwing back in??
Cheers.
Cheers.
- jim
- Visitor
12 Nov 2015 17:50 #156120
by jim
Replied by jim on topic Changing the antifreeze/coolant
Just popped my head under and had a look at mine the plug is twist open by hand on passenger side. I don't think you need to replace anything just do it up tight.
Remember to flush the system well especially if you change to different type of coolant.
Which type of coolant will you be using?
- Thank you received: 584
12 Nov 2015 18:20 - 12 Nov 2015 18:22 #156124
by facade
Replied by facade on topic Changing the antifreeze/coolant
The radiator drain only drains the radiator. Most of the water stays in the engine block and the heater.
However, The Manual says to drain it here, top up again, leave the rad cap off and run the engine until the top hose gets hot (thermostat open) then drain again, and repeat until the water is clear.
This avoids nasty airlocks in the heater.
Then you empty out the expansion bottle, tip the required amount of neat antifreeze into the radiator and fill with water, (I usually squeeze & release the hoses a few times to get air out) run the engine (rad cap off) until the thermostat opens, whilst adding water to keep it full, then pop the rad cap back on, and half fill the expansion bottle with antifreeze mixture.
Run until the temperature gauge comes up, then switch off, and when cold, fill the radiator right to the top, fill expansion bottle to the line, and check the level in the bottle when the engine is cold a few times over the next couple of days.
Don't ever take the radiator cap off when the engine is hot - you can leave it off from cold and then run the engine.
Last edit: 12 Nov 2015 18:22 by facade.
The following user(s) said Thank You: gusthegorilla, jim
- jim
- Visitor
12 Nov 2015 18:33 #156126
by jim
- Graphite675
- Visitor
12 Nov 2015 18:46 #156130
by Graphite675
Replied by Graphite675 on topic Changing the antifreeze/coolant
Any suggestions as to which antifreeze/coolant to use?? I was planning on getting something from Halfords.
Cheers
Cheers
- jim
- Visitor
12 Nov 2015 18:55 #156133
by jim
The halfords spec charts at the coolant section advised Halfords OAT (organic acid technology) red silicate free coolant for Jimmy.
www.halfords.com/motoring/engine-oils-fl...-antifreeze-5-litres
07 Sep 2018 12:05 - 07 Sep 2018 12:16 #195761
by Bosanek
Replied by Bosanek on topic Changing the antifreeze/coolant
Facade's instructions seem very fine indeed, except for one issue - achieving a proper ratio mix of coolant and water in the end.
If you do a flush like Facade suggests, I don't see when there comes a point when all the fluid is expelled from the entire coolant system (radiator, expansion tank, engine block, heater core)?
That is an issue if the system will be filled with a pre-mixed coolant in the end of the process. Pre-mixed coolants are usually a 50/50 mix (coolant/water).
Now, if at no point in the flushing procedure the entire cooling system can be fully drained, this means that the system will contain say at least 2 l of (almost) pure water before the final new coolant fill.
Now, if you fill in say 4 liters of a 50/50 pre-mixed coolant , that coolant will mix with say 2 liters of water which is already in the engine block or in the heater. This will finally give about only 25% (2 l) of coolant in the entire 6 litre mix. This severely raises the freezing point of the mix, and decreases its corrosion protection capacity.
So, how to resolve this issue when using a pre-mixed coolant to fill the system? I would certainly like to drain almost everything from the entire system before doing a final new coolant fill. How to achieve this? And how to avoid or resolve possible air pockets in the heater core, engine block or somewhere else?
P.S.:
Someone would probably comment "well just use concentrated coolant and control your own mix". I would gladly, but almost all Japanese engines require coolant chemistries which are specific to them and quite contradictory to most European coolants, and having anything Japanese in my country is like having a space ship. It can be quite an endeavor to find ordinary parts for Japanese cars, let alone dedicated coolants. The only Japanese-suitable coolants (non-silicated, phosphated OAT coolant types) which I can find here are already pre-mixed, no concentrates.
P.S.:
Last edit: 07 Sep 2018 12:16 by Bosanek. Reason: Typo
- TomDK
- Visitor
07 Sep 2018 12:13 #195762
by TomDK
Replied by TomDK on topic Changing the antifreeze/coolant
Come on guys..
This isn't exactly rocket science. Sometimes some of these fairly easy DIY task gets way overcomplicated due to stupidely long instructions and what not keeping the owner from doing any thinking for themselves.
Drainging the radiator also drains a good deal of coolant from the engine. At least that's what the amount of coolant in the bucket tells me.
07 Sep 2018 12:17 - 07 Sep 2018 12:18 #195763
by Bosanek
Well I drained the radiator and the expansion tank and only about 3.5 l of fluid came out. According to the specifications, cooling system's capacity is 6 liters.
Is there any accessible drain point in the engine block and/or heater core which can be opened to let the cooling fluid out?
Last edit: 07 Sep 2018 12:18 by Bosanek.
- Thank you received: 552
07 Sep 2018 22:20 - 07 Sep 2018 22:35 #195775
by Scimike
Replied by Scimike on topic Changing the antifreeze/coolant
Just done my 2009 VVT with aircon as per the manual.
Drained via the radiator tap. Filled and flushed several times until the fluid ran clear. Filled with Halfords Red OAT antifreeze.
Approx 5 ltrs came out each time, 5 ltrs went back in. I measured each time so I was 100% sure I had no trapped air. I allowed for the approx 1ltr left in the system ( now clean due to flush/engine run) when I mixed my antifreeze. I used the concentrate and deionized water from Halfords, so I should have a near perfect 50/50 mix.
Very simple.
Very simple.
Last edit: 07 Sep 2018 22:35 by Scimike.
- Caelite
- Visitor
08 Sep 2018 01:42 #195781
by Caelite
Replied by Caelite on topic Changing the antifreeze/coolant
As above facades guide is pretty much spot on. Personally I err on the side of a 60-75% mix after a full flush (I ran 5 or 6 full runs of water as my system was properly scummy). Erring for more coolant simplifies the issues bosanek outlines. Coolant mix doesn't have to be an exact science, as long as there is enough water to make it flow well and enough coolant to stop it rusting/freezing.
All I would add is, be careful with the wee drain plug. I would advise unscrewing from the top rather than underneath, and stop unscrewing when it begins to dribble, make sure your basin is as far back from the dribble as possible before unscrewing the rest of the way. The way the Jimnies drain plug is designed when you pop it off it pisses coolant EVERYWHERE, with some force. Not fun when it's at 90C and your face is under the car.
08 Sep 2018 07:59 #195788
by facade
If you can only get pre-mixed coolant, and you know it will mix with what is in there, just drain what you can, and top up with new, run it a few days and do it again, wastes some of the new coolant, but will get nearer what you want.
tbh, anti-freeze lasts pretty much forever, it is the anti-corrosion additives that get used up, so renewing 75% of the antifreeze should be fine.
(50% the first time, then 50% the second time, but half of what was left will be old, so 75% overall- and you will need 25% extra to waste)
When I get around to doing the woefulRenault Nee-San, I will drop what is in the radiator and fill it back up with Prestone, which (apart from using super special Ne-San fluid, not Prestone universal) is how the main agents* do it, leaving 50% of the old coolant there.
*If you find out and query the process, the agent fobs you off with "It is a coolant REFRESH" (according to the boys in the Nee-San club)
Their idea of a flush is exactly as the Jimny, keep adding fresh water, run it and drain, and then they add concentrate and do the final top up with water to get to 50%.
Time to create page: 0.160 seconds
