BigJimnyMeet 2024
Loud rapid "clicking" or "burr" noise - gearbox ??
17 Aug 2015 20:14 - 17 Aug 2015 20:15 #150004
Loud rapid "clicking" or "burr" noise - gearbox ?? was created by mlines
2005 VVT (yes - the dreaded year for gearbox issues)
Suddenly started making a noise in 3rd and 4th Gear only. (Going to work - fine, coming home - noisy)
Noise is like when we would put cardboard in the rear wheel of our pushbikes when kids to pretend it had an engine.
No noise in 1st, 2nd or 5th or reverse,
Only makes noise when moving.
No noise when clutch is depressed whilst driving.
Noise is the same in 2wd and 4wd.
Noise on acceleration and over-run, but by "balancing" the throttle when going from acceleration to over-run (i.e when no load on transmission at all) the noise goes.
Any ideas on the issue??
Last edit: 17 Aug 2015 20:15 by mlines.
- zukiara
- Visitor
17 Aug 2015 20:23 #150007
by zukiara
Replied by zukiara on topic Loud rapid "clicking" or "burr" noise - gearbox ??
Mm 3rd-4th gear syncro bearing or collar spinning on the main-shaft
- Thank you received: 581
17 Aug 2015 22:16 #150031
by facade
Replied by facade on topic Loud rapid "clicking" or "burr" noise - gearbox ??
I agree, could be the splines on the mainshaft, or the centre of the synchro hub is split and opens up enough for the splines to go round. A selector fork problem that doesn't move the hub outer far enough to get the dog teeth fully into engagement would cause it to kick out of gear.
If it was the front countershaft bearing failed it wouldn't do it in 4th,as the drive doesn't go through the countershaft
The gearbox needs to come apart.
The following user(s) said Thank You: mlines
18 Aug 2015 10:42 #150055
Replied by mlines on topic Loud rapid "clicking" or "burr" noise - gearbox ??
Well as this is a daily drive we do not have the luxury of playing around with it in the garage.
Therefore I have booked it in with a local gearbox specialist for diagnosis and rebuild. They have fixed labour costs of £360 for the rebuild plus parts which seems competitive based on places like CAM-SUZUKI quoting close to £1000 for a used gearbox.
18 Aug 2015 13:37 #150063
Replied by mlines on topic Re:Loud rapid "clicking" or "burr" noise - gearbox ??
£360 is the fixed labour charge, parts are extra!
Sent from my Nexus 5 using Tapatalk
18 Aug 2015 13:38 #150064
That's for a removed box. £280 if they remove/re-install box
18 Aug 2015 13:40 #150065
New box is £1800+vat from suzuki
- Thank you received: 28
18 Aug 2015 13:59 #150067
by fozzie
2012 Jimny Black. Totally standard (except for rear seat removal mod).
Replied by fozzie on topic Loud rapid "clicking" or "burr" noise - gearbox ??
£1800 is frightening!
I was lucky with mine as I'd only had the car 2 months before the noise started. I didn't buy the extra (insurance based) warrantee and had to play the 'not fit for purpose' excuse for the Suzuki dealer to repair it. Even then it was touch and go.
In my honest opinion, the way you are going certainly is the best. Good luck with the repair.
19 Aug 2015 08:42 #150143
Well it just about made it to the Gearbox place this morning. Was getting worse and worse on the way, suspect we have a gearbox casing full of bits of bearings etc.
19 Aug 2015 16:51 #150185
by fozzie
Have you heard yet? Or haven't they started?
20 Aug 2015 18:58 #150257
Well I phoned them at lunchtime for a progress report.
They said they would ring back.
After 90 minutes they did ring back and said "Its making a noise in 3rd and 4th" which is what I told them anyway,
So they have had it since 08:00 am yesterday and only drove it on a test drive this lunchtime when I phone up, NOT a very good start. Here's hoping they pull their fingers out!
P.S when my son drove it onto their forecourt I noticed a strange noise from the front, they said today that a front wheel bearing has collapsed. How is that for unlucky as it was fine the previous evening when I drove it to test the gearbox. Still I told them NOT to fix the bearing.
- Visitor
20 Aug 2015 19:36 #150264
Replied by Daniel30 on topic Loud rapid "clicking" or "burr" noise - gearbox ??
I had a gearbox go on a Ford galaxy when I was getting it repaired I was chasing them all the time they seemed to be so relaxed about it?...... So frustrating so keep ringing them fir updates otherwise Monday they will tell you the same thing
