BigJimnyMeet 2024
How to fit Ignis sport recaro into a Jimny
- GRAYWOLF
- Visitor
01 Aug 2018 08:15 - 01 Aug 2018 16:05 #194755
by GRAYWOLF
Replied by GRAYWOLF on topic Re:How to fit Ignis sport recaro into a Jimny
Got the runner lowers off, what a pain, dry fitting seat complete to jimny b4, i found front right hand bolt fitting, needed to be cut off, and rewelded onto insde of runner, rear fitting needs to be redrilled approx 1/2 in..inward.
front left fitting would also need cutting off and fitting outboard, and rear left would need compete cut and shut..this is iff, you were to use original mounts on ignis..however , as a plus..i have both my front seats fitted with a 30mm.lift spacer all round, and, i could dispense with these, due to extra height of ignis seat, but, i think it will be more benficial to fit Jimny raqils to Seats.
Hopefully complete today..if i can get it all reassembled..!
Last edit: 01 Aug 2018 16:05 by Lambert. Reason: Swearing
- Thank you received: 1759
09 Aug 2018 17:46 #194955
Replied by Lambert on topic Re:How to fit Ignis sport recaro into a Jimny
If you are having trouble getting the seats to run free try putting a couple of washers under each front bolt tab it stops the rails tweaking over when tightening up.
22 Mar 2020 17:26 #220150
by Lomax
Replied by Lomax on topic How to fit Ignis sport recaro into a Jimny
Hello, I am going to try a set while I am stuck at home. What size of bar do I need? Also if I don’t have access to a welder, could I use the likes of JB weld?
22 Mar 2020 17:35 #220152
Replied by Lambert on topic How to fit Ignis sport recaro into a Jimny
8mm off the top of my head and I really wouldn't trust an epoxy, ok it for the seat back release but I would want a proper job.
22 Mar 2020 19:50 #220158
by Lomax
Thank you, will try get a pal to weld it.
22 Mar 2020 20:16 #220160
by Lomax
Oh last question. Is the bar on the swift seat the same length? It would be easier for me to get that one welded, as it will enable me to keep my current seats In use.
23 Mar 2020 04:56 #220176
No it's totally different ends and too long. It's possible to find a replacement in a scrap car but I haven't bothered yet.
23 Mar 2020 16:59 #220189
Replied by Riccy on topic How to fit Ignis sport recaro into a Jimny
You can do it without a welder...
The bar from the Jimny seat that needs extended is hollow. I just cut it and used a tap to thread the inside of it out to M6 (possibly M8? i cant remember). I then used a bit of threaded rod and a couple of nuts to secure it. This was handy as it allowed a bit of adjustment to get the length just right and the securing nuts make it stay together properly too
05 Apr 2020 14:39 #220720
by Lomax
- Reason2doubt
- Thank you received: 100
07 Apr 2020 03:45 #220764
by Reason2doubt
Replied by Reason2doubt on topic How to fit Ignis sport recaro into a Jimny
- Max Headroom
- Banned
- Thank you received: 217
08 Apr 2020 22:11 #220828
by Max Headroom
Replied by Max Headroom on topic How to fit Ignis sport recaro into a Jimny
They even LOOK comfy
