BigJimnyMeet 2024
Fan belt/ Alternator belt squeal on start up
- BensJimny
- Visitor
07 Jan 2014 20:43 #99554
by BensJimny
Replied by BensJimny on topic Fan belt/ Alternator belt squeal on start up
i was always unsure on putting lubricants on rubber belts, i've found a dry bar of soap smeared on the inside of the belt aids movement and to my knowledge doesn't damage the rubber and removes squeaks! give it a try?
- JimnyKarl
- Visitor
15 Jan 2014 22:57 #100751
by JimnyKarl
Replied by JimnyKarl on topic Fan belt/ Alternator belt squeal on start up
I have the same problem squeal like mad changed both belt still dose it no matter how tight i get the Alternator belt if i slacken the Alternator belt off it stops squealing but then does not charge the battery. i think its the Alternator pulley that is the cause, yes i have tried and exhausted all options so have now ordered a new Alternator. will let you know if that works.
- ands
- Visitor
28 May 2014 02:09 - 28 May 2014 02:10 #116492
by ands
Replied by ands on topic Fan belt/ Alternator belt squeal on start up
my jimny also squeaks. already had the alternator and alternator belt adjusted/tightened but still squeaks once in a while. will try to clean the belt and the pulley with soap and water first.
by the way, is it easy to DIY replace the belts?
Last edit: 28 May 2014 02:10 by ands.
- jonesyba420
- Visitor
28 May 2014 07:06 #116501
by jonesyba420
Replied by jonesyba420 on topic Fan belt/ Alternator belt squeal on start up
Alternator belt is easy power steering belt is abit more difficult.
- Thank you received: 116
28 May 2014 16:49 #116528
by maverick
Jalapeño, IISY?
Replied by maverick on topic Fan belt/ Alternator belt squeal on start up
This might help, from Big Jimny "How To" Section, which i always struggle to find :-
www.bigjimny.com/images/documents/changi...er_steering_belt.pdf
Jalapeño, IISY?
- rexthecat
- Visitor
28 May 2014 18:50 #116543
by rexthecat
Replied by rexthecat on topic Fan belt/ Alternator belt squeal on start up
Draw from the battery putting more on the alternator? Once the battery back to charge squeal goes.
- Merz
- Visitor
05 Jun 2018 07:05 #193219
by Merz
Replied by Merz on topic Fan belt/ Alternator belt squeal on start up
I know this is an old post, but I have been having endless trouble with my Suzuki Jimny 1.3 '07 model. The fan belt keeps coming off. Sometimes, there is a squeal first other times there is no noise at all and it simply comes off. This is proper disaster as I live in a very dangerous country...so sitting on the side of the road and waiting for tow trucks is nerve wracking!
My mechanic has been repairing my vehicles for the last 30 years. He hasn't struggled like this before.
We checked:
pulley alignments
we lathed the pulleys to remove pockmarks
changed the pulley
checked the gearbox and engine mountings
had the alternator serviced by 4 different auto electricians
installed a suzuki original belt
In the end, we were left with 2 options. Either replace the alternator or...the battery is a problem. We decided to focus on the battery. I took my battery to a battery center and there was no issue with the battery. The car spec is for a 45 amp/h battery but...there was a 35amp/h battery fitted. I called a number of battery centers and none of them had a 45amp/h battery with the small battery terminals. ALL of them recommended I just take the 35 amp/h battery which has the small terminals. Some of them insisted you don't get 45amp/h batteries with the small terminals. After some searching, I found a battery distributor that sells 45amp/h batteries. Since the change to a the bigger battery I have had no issues.
We checked:
pulley alignments
changed the pulley
05 Jun 2018 07:09 - 05 Jun 2018 07:11 #193220
Replied by mlines on topic Re:Fan belt/ Alternator belt squeal on start up
Just a note. A number of batteries have what I call "peelable" terminals. The terminals are fat but the outer layer of them can be lifted or peeled off to make a small terminal
Last edit: 05 Jun 2018 07:11 by mlines.
- Thank you received: 923
05 Jun 2018 09:46 #193222
Replied by X8GGY on topic Re:Fan belt/ Alternator belt squeal on start up
Mine squeals for the first minute or so too...
The alternator struggles at first to charge the two batteries, but settles down after a minute or two...
05 Jun 2018 09:56 #193226
by maverick
Jalapeño, IISY?
Replied by maverick on topic Re:Fan belt/ Alternator belt squeal on start up
I don’t understand why the fan belt would come off due to a battery problem??
Jalapeño, IISY?
05 Jun 2018 10:00 #193228
- Max Headroom
- Banned
- Thank you received: 217
05 Jun 2018 21:26 - 05 Jun 2018 21:36 #193235
by Max Headroom
Replied by Max Headroom on topic Fan belt/ Alternator belt squeal on start up
Hi Merz
This may not be relevant to your situation, but my neighbours Jimny had a problem, not with the belt coming off, but with it squealing badly on start up.
The belt was changed and adjusted on several occasions but continued to have the problem. We had tried dusting the fan belt with French-chalk dust to absorb any spilt oil etc, but the remedy was only a brief cure before it started squealing again.
The alternator was checked by a very good local garage, and found to be perfectly serviceable, however...
...One day, on a cold morning, I started it, and had the need to put the heater fan on, and the wipers, along with the lights, (and it also happened that the radio was on as well).
The more 'services' that were demanded from the car, the more it made the fan-belt shriek like a banshee!
The final fix was (in spite of its apparent serviceability) to replace the alternator.
The symptom was as if the more load that the alternator was subjected to, a physical resistance to the alternator actually turning seemed to build up, to a point that it was trying to stop, thus causing the belt to slip.
This was a phenomenon that neither I had seen, or the engineers at the garage had seen before.
(The initial brief squeal on engine start-up was probably due to the load being taken at the starter motor)
This sounds slightly similar to your problem. If the alternator has not been changed, it might be the only thing left to try
Last edit: 05 Jun 2018 21:36 by Max Headroom.
Time to create page: 0.141 seconds
