BigJimnyMeet 2024
× A place for more technical discussions. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
KEY PROGRAMMING
  • jimothy
  • Visitor
  • Visitor
18 Dec 2013 18:17 #96679 by jimothy
KEY PROGRAMMING was created by jimothy
Is there a way to program the keys for a 2007 Jimny. ie immobiliser+ the central locking.
Jim :) :)
27 Jan 2014 19:28 #102275 by auchenblae
Replied by auchenblae on topic KEY PROGRAMMING
The key has a little chip in it with a unique number and you need the Suzuki kit to tell the car that a key should start the car. Oherwise go to Timpsons and they will kut a key for you and copy the unique number of a proper key to the copied key cost £35 but will take a few days to get in stock.
If you have the key with the remote in it then to programme the remote you need to go over the instructions available online to teach it to the car. the instructions have a mistake in them.
You still need to use the Suzuki kit to tell that key to start the car.
Unlike in some other cars if you lock the car with a remote you can unlock the door it with the key. Not in my MK3 MX5 or Impreza without the alarm going off.
eddie
eddie
16 SZ3
07 JLX+ gone 16
99 JLX gone 07
27 Jan 2014 20:46 #102288 by Rhinoman
Replied by Rhinoman on topic KEY PROGRAMMING
I think that there is a sequence for the remote locking. The key can be matched using the Suzuki kit, some locksmiths tools or using an SDL interface.
27 Jan 2014 21:51 #102300 by Grasshopper
Replied by Grasshopper on topic KEY PROGRAMMING
I know that I have the Suzuki service supplement covering my 2002 remote key code procedure (if that the same), just need to find it. Should have been with the manual will have another rummage ASAP.
The only benefit of age is experience.
27 Jan 2014 22:31 #102311 by Grasshopper
Ok this worked for me on a 2002 model, important bit is leave drivers window open.
RG413, RG415 & SN413 (Japanese built Ignis &Jimny Models)
Transmitter Code Registration Procedure
If transmitter or door lock controller is replaced with a new one, register key code as follows:
1. Confirm that the vehicle is in the following condition.
* All doors are closed
* Ignition key is out of ignition switch
* Driver side door is unlocked and its window is open.
2. Disconnect negative (-) cable from battery.
3. After 30 seconds, perform the following procedure within 60 seconds.
a) Connect negative (-) cable to battery
b) Operate drive side door lock button (1) from lock to unlock twice
c) Push 'LOCK' button on transmitter and confirm that all doors cycle from unlock/lock/unlock
d) Push driver side door lock button to 'LOCK' position
e) Push 'LOCK' button on transmitter twice and confirm that all doors cycle from unlock/lock/unlock
With this, code registration is completed.
NOTE:
* Two transmitter codes can be registered at the same time
* When the third transmitter code is registered, the oldest one will be cleared automatically
29 Jan 2014 15:41 #102518 by Basketcase
Replied by Basketcase on topic KEY PROGRAMMING
For a 2007 reg you'll need to take it and all keys you want to work the car to a Suzuki dealer it's done through the Suzuki computer and clears all keys then re loads the data back to the keys(assuming you have the key with lock and unlock buttons on it)
11 Apr 2018 17:55 #191583 by Bosanek
Replied by Bosanek on topic KEY PROGRAMMING
I decided to continue in this topic instead of making a new one, as I believe that I have a similar situation.
It is a petrol Jimny made in 2013 in Japan (type 9 model).
It originally had a standard key (no buttons on it) plus a separate remote controller for remote central locking of all vehicle's doors.
Well that remote controller thingy got lost.
Now the car can be (un)locked only by putting the key in a door lock, like in an old vehicle.
So, there are now two questions:
1. Where to obtain another remote controller (Suzuki dealers ask a high price ...)? Perhaps from a vehicle junkyard, or new aftermarket of the same quality?
2. How to program the new remote controller to the car?
  • Riccy
  • Riccy's Avatar
  • Banned
  • Banned
  • J999 MNY Bashing around Carlisle
11 Apr 2018 18:02 #191584 by Riccy
Replied by Riccy on topic KEY PROGRAMMING
No eBay APP ID and/or Cert ID defined in Kunena configurationDont know about programming it (auto electrical specialist?) but the key is easy to get:
12 Apr 2018 10:15 #191612 by yakuza
Replied by yakuza on topic KEY PROGRAMMING
I bought this or a similar item. It works and I can program my excisting keys in my 2005 jimny.
You will need the correct immo chips to program it to your car.
The following user(s) said Thank You: SpamJ
12 Apr 2018 10:17 #191613 by yakuza
remember that not all Jimnys have the reciever for the remote so on my car i could not program a remote even though the car data from suzuki said i could.
12 Apr 2018 17:50 #191629 by helijohn
Replied by helijohn on topic KEY PROGRAMMING
yakuza wrote: remember that not all Jimnys have the reciever for the remote so on my car i could not program a remote
This has me a little confused because if you don't have the receiver then can't you simply use a non coded key?
Do it right - use Hammerite
When the blue light is flashing I am kidding.
13 Apr 2018 06:50 - 13 Apr 2018 06:55 #191648 by yakuza
The programmer is used for the immo chip, the small one below the key on the picture of the key above here.
There is an antenna/signal booster near the ignition key and your key (chip) have to be programmed to the ECU.
The reciever for the remote lock/unlock button sender is a different thing and not all jimnys have it.
I tried to use a key remote like the one above here but there is no reciever on my car.
I have installed an aftermarket reciever/key sender hooked up to the wiring for the buttons in the door.
Last edit: 13 Apr 2018 06:55 by yakuza.
Powered by Kunena Forum
