BigJimnyMeet 2024
× A place for more technical discussions. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Tyre Sizes - Rough Guide Thread
  • 1066Boy
  • Visitor
  • Visitor
18 Oct 2016 15:54 #173712 by 1066Boy
Replied by 1066Boy on topic Tyre Sizes - Rough Guide Thread
One thing worth mentioning is the diffence between standard tyres and remoulds.
My tyres are remould Muds in standard size (205/70)
Even with my 2" lift they only just fit and I still had to remove the mudflaps ! :)
19 Oct 2016 10:40 #173735 by Bosanek
Good point. I have added that to my document and to the wiki.
The following user(s) said Thank You: 1066Boy
  • Maher
  • Visitor
  • Visitor
24 Nov 2016 22:38 #174891 by Maher
Replied by Maher on topic Re:Tyre Sizes - Rough Guide Thread
Hello Guys, hello Nate,
I have a question, I bought from jimny bits a 2" body lift and wheel spacers and 215 -75 / 15 Bfgoodrich tires, but I was told by my mechanic that the body lift will affect the factory ride quality and the ride will become stiffer on roads, even though the website says other wise, I wanted to know since you have the same lift if the rides stiffens and handling is affected, my jimny is a daily driver and I ocaisionaly take it off-road.
Thanks
24 Nov 2016 22:49 #174892 by jackonlyjack
the body lift will not change anything ;)
i suppose it will be 2" taller and effect the COG a tiny bit
the ride will feel the same i am sure :)
Jack
p.s maybe your mechanic just doesn't want to do it so trying to put you off :unsure:
15 Dec 2016 15:54 - 16 Dec 2016 14:07 #175688 by Bosanek
I am informing the public that I have finished all my additions to the Wiki article about tyre sizes, models and best usage practices.
The article is located here:
www.bigjimny.com/mediawiki/index.php/Tyr...age_-_best_practices
I consider that article 98% finished.
Part of the content of that article (the last three chapters) is replicated in another wiki article about improving and modifying Jimny for mixed on-road and off-road use: www.bigjimny.com/mediawiki/index.php/Imp..._and_all_terrain_use
By the way, that article is also 98% finished as far as I am concerned.
Last edit: 16 Dec 2016 14:07 by Bosanek. Reason: Link correction
16 Dec 2016 14:08 #175709 by Bosanek
Well it ain't over until it's over.
After sleeping it over last night, I had some more ideas and some refinements to add. So now those should finally be (almost) finished.
  • paradox1001
  • Visitor
  • Visitor
20 Mar 2017 10:39 #179426 by paradox1001
Replied by paradox1001 on topic Re:Tyre Sizes - Rough Guide Thread
fshdck wrote: 215/75 R15 Hankook MT RT03 initial experience.
Tires fitted on standard 15x5.5 steels, balanced easily between 40 and 80 grams per wheel.
Look very nice.
On standard, bit sagging 13 year old suspension there is no rubbing, even at flex but it's quite close. Anti roll bar wasn't removed.
Haven't done a lot off road driving yet, but the tires seem to perform good, no wheel spins on wet dirt tracks, gravel and grass at road pressures. Need to test them more extensively, but so far I'm happy.
Road noise is minimal, all I can hear is a little hum at motorway speeds, but the car is noisy anyway, and I might not be very sensitive to tire noise, so your experience may vary.
They handle excellent on dry tarmac, and surprisingly good on the wet too. The car wasn't pushed into extreme, but they seem be better on the road then budget road tires it came with.
Ride is noticeably softer due to tire size with 26/23 psi front/rear despite stiff sidewalls (tire is LT rated). Chalk test showed even wear of chalk at 22-21/20-19 psi, but it seems a little low for road use so I'm running 25/22 psi. Might drop the pressure down for heavy rain and winter. Lower pressures didn't seem to affect the handling apart from making the ride even more comfortable, and using a bit more fuel. After some more mileage I'll check the wear and maybe adjust the pressure then.
Fuel efficiency didn't suffer much, unless on lower pressures. I'd say it's 5-15% drop compared to 205/70R15 road tires, but it's a rough estimate.
Performance dropped, mostly due to up sizing. Not very noticeably at town speeds, but acceleration from 50 to 70mph in 5th gear takes ages. Cannot compare to road tires, cause I didn't drive on motorways while having them on the car. Braking seems to be unaffected.
Conclusion: not really MT tire, more like aggressive AT, grippy, quiet and comfortable. Winter performance might be sketchy due to lack of siping, time will tell. I'm having high hopes for them to make a decent all season tire cause rubber compound is pretty soft, but it's too early to draw such conclusions yet.
Hi mate I know I'm replying to an old post
I was wondering how you have found these tyres over the time you have had them
Also will they fit on the standard door mounted spare wheel carrier?
  • fshdck
  • Visitor
  • Visitor
01 Apr 2017 20:46 - 01 Apr 2017 20:47 #179827 by fshdck
Replied by fshdck on topic Re:Tyre Sizes - Rough Guide Thread
Hi. Everything from my previous post still stands.
After 2000 miles there is minimal wear and no difference in handling or noise (probably 'yet' :) ).
Global warming prevented me from driving on snow, so I can't comment on winter performance. Some German reviewers rate them 'good' for winter use but I suppose it depends on driving style.
I drive like an old lady, so might have not noticed any issues that occur if you thrash the car around. Keithy on here commented in another thread, that they slip/spin on wet tarmac but he has bigger engine and a turbo (I think), so, there you go :)
Overall I'm happy with these tyres. They are a good buy at reasonable price and I would recommend them.
Oh, and they fit the spare carrier without problems.
Here's a few links to videos (not mine) featuring these, might help you decide :)
On Mitsu pickup truck:
Quite extensive testing in Russia. Long video, but worth watching if you consider this tyres:
UAZ in the snow:
I hope that helps. If anything, Keithy is the man you are after. He has got more driving experience than I and had these tyres longer, so he might have more insight.
Cheers.
Jake
Last edit: 01 Apr 2017 20:47 by fshdck.
03 Sep 2017 09:10 #183827 by grumyoldjoe
Anyone put new duellers back on their jim ?
www.blackcircles.com/catalogue/bridgesto...T/96/f?tyre=35807163
Its tyre time for me soon so might just go with duellers that came with the car in 2013 new
Wine improves with age.
  • Lambert's Avatar Topic Author
03 Sep 2017 11:38 #183829 by Lambert
Don't do it. I used to be quite happy with mine until I got some proper rubber. I have bfgs and love them.
03 Sep 2017 13:18 #183831 by grumyoldjoe
Im on standard and 95% tarmac use. Plus I dont think my budget will stretch to 500 notes for 4 new corners.:unsure:
03 Sep 2017 14:18 #183832 by jackonlyjack
No eBay APP ID and/or Cert ID defined in Kunena configurationI think 11/60 as these ;)
Time to create page: 0.169 seconds
Powered by Kunena Forum
