THE DEATH WOBBLE THREAD
Casey wrote: Concrete on a plate, concrete on a plate... That's right, unlike jelly it doesn't wobble.
My new steel wheels and tyres were delivered this afternoon, so I went straight out and replaced my alloys.
I decided to go for steels with General Grabber ATs 205/75/15, which came already ballanced. They weren't cheap but this is the only thing I've done to my Jimny since buying it last October. When I saw them I was seriously worried they weren't going to fit under my unlifted arches as they looked much bigger than the 205/70/15 I had on. Anyway I needn't have worried there was plenty of space and no rubbing at full lock.
But what's more I just took them for a spin and NO WOBBLE. I could hardly believe it, in fact about an hour later I took it out again and not the slightest shake. It feels so much better. Hooray...
These are they.
Can't believe it. Just when I thought all my problems were over, I took it into Quickfit for an MOT Thursday, it flew through but next day the wobbles back. I can only think it's got something to do with them taking the wheels off to check the brakes. Took the two front wheels off and cleaned the hubs but made no difference, still wobbling at 45.
- Thank you received: 153
They are known to increase their work with dirty tricks!
- rogerzilla
- Thank you received: 64
Discs rarely warp. What seem to be warped discs are nearly always discs with serious runout or, more likely, disc thickness variation (DTV). This is caused by the discs, or sometimes the wheel, being incorrectly fitted - disc to dirty hub, or wheel nuts not tightened progressively and in the correct pattern. This means that the disc is fitted with a small amount of runout, not enough to cause pedal pulsing but still outside the manufacturer's specification. As the disc rotates millions of times over the next few months, the pads "kiss" the disc at the high spots. There is no real pressure involved and no impact on fuel consumption but this is enough to wear the disc excessively a tenth of a millimetre or more at those points. after about 3,000 miles you get the pulsing brake pedal. The only cure is new discs (and pads, of course), correctly fitted this time.
Vibration that first occurs mmediately after the fitting of new discs or the removal of a wheel can be fixed by removing both wheel and disc and refitting correctly. The damage takes a few thousand miles to build up.
When fitting new discs you MUST clean all dirt and rust off the hub. A rotary wire brush is the usual tool. In an ideal world you then fit the disc and check for runout with a dial test indicator, but it's near-impossible to use a DTI on a car where the disc is retained solely by the clamping force of the wheel.
Wheel nuts should never be tightened in a circle, never witrh an air tool and never to the full torque on the first go. With 5-stud hubs, first tighten enough to allow lowering the car to the ground without pulling it off the jack, then use a torque wrench to get the nuts to about 70Nm, skipping every other nut as you work your way round the hub (this is as close to "opposites" as you can get with 5 studs) until all five have been done. Then repeat with the torque wrench set to the full torque, which is 110Nm-120Nm for most cars.
When you've finished, spin the wheel and listen to the noise of the pads on the disc. Runout is obvious with experience; you're listening for a more-or-less constant noise, not an intermittent scraping.
It is possible to ruin a disc simply by fitting the wheel with an air tool wound up to 120Nm and going round the hub in a circle. The big tyre places are very bad for this, and as I have two sets of wheels I always take the loose wheels in for tyres, rather than allow them to fit them to the car.
- rogerzilla
Don't rule out the simple possibilities like flatspotted tyres. Jimnys run very low front tyre pressure and a car that has been sitting round for only a week, especially in the cold, could have developed a bit of a flat spot on each tyre which will take a few miles to even out. i wonder if this was the case with the green Jimny above, which wobbled after being unused for a while?
- DonegalGuy
- Visitor
How is the piston supposed to release the pads anyway? there must be an opposing force to release it after you use the brake pedal. Stand on the brake pedal and fluid pushes piston....release pedal and ??? isn't the fluid still there behind the piston, in the brake hose forcing the piston against the pad? Confused dot com!
- Northern-Wanderer
- Visitor
- idiotmobil
- Thank you received: 118
JIMNYLESS
- jonesyba420
- Visitor
- Ryan270990
- Visitor
