BigJimnyMeet 2024
Front brakes
24 Oct 2013 20:37 #87804
by Rhinoman
If you are lifted then you get a greater weight shift to the front so improved front brakes only does make some sense.
Replied by Rhinoman on topic Front brakes
rayz_x wrote: I'm no expert on the Jimny but agree with the points above. It doesn't matter how efficient you make the front brakes if you don't improve the rear ones it won't help. As soon as the front wheels start to lock up the ABS will release them.
Ray
- rayz_x
- Visitor
25 Oct 2013 16:16 #87920
by rayz_x
Replied by rayz_x on topic Front brakes
I see your point, but on the road you could have a very light rear end at times!
Ray
Ray
- darthloachie
- Visitor
26 Oct 2013 16:12 #88046
by darthloachie
Replied by darthloachie on topic Front brakes
if you're offroading the rear drums fill up with mud and hey presto no brakes
06 Sep 2019 10:08 #213197
by AFCBTezza
Replied by AFCBTezza on topic Front brakes
Hi Dave cc
Please could you tell me if your g-wagon brakes would fit my M13A 2003 Jimny Auto?
Or if anyone else knows of any other brake upgrade possible without costing too much money, or adjustments.
Would appreciate a link also.
Thanks
Thanks
- Thank you received: 1761
06 Sep 2019 12:57 #213204
Replied by Lambert on topic Front brakes
If you are not wanting to modify components the best option is something like ebc greenstuff pads new disks and fresh brake fluid. All of which are effectively oem parts but just a bit better. After that you're going to want a rear disk conversion and braided lines and vented front disks with vitara calipers and high boiling point brake fluid. After that the only other thing is serious money on a custom big disk and multi piston caliper setup.
The following user(s) said Thank You: AFCBTezza
06 Sep 2019 16:34 - 06 Sep 2019 16:35 #213218
Replied by Riccy on topic Front brakes
EBC do a kit with greenstuff pads and some of their OE spec discs (in 107 and 108mm sizes conveniently). £102.11...
www.ebcbrakeshop.co.uk/info-brake-parts?...+centre+hole%29&bhp=
after that, as Lambert says, have a google for 'wilwood' who make a nice but expensive kit...
www.sd-performance.com/eng/showProduct1.asp?psid=315
Last edit: 06 Sep 2019 16:35 by Riccy.
Time to create page: 0.142 seconds
