Stopping the flashing 4WD light with pictures
- Thank you received: 260
Rhinoman wrote: I just got back from Tong, 4wd worked perfectly and no flashing light.
Result.
- JimnyUser
- Visitor
JimnyUser wrote: what did you use for your 'decent blanking plug'??
In my case initially a bit of tubing (which may have been the original vacuum piping?) with a bolt in the end which worked perfectly well then I ordered some silicone blanks off eBay..
- JimnyUser
- Visitor
Took some pics along the way, I can confirm it works great by shorting the vacuum switch connector.
The temporary blanked off manifold takeoff...
The shorted vacuum switch connector using a bullet connector...
The connector back in situ wrapped in insulation tape and the solenoids are still in position...
All the vaccum pipes have been removed making for a much neater and accessible front axle, ie; less rust th eonly pipe remaining is this one that goes into the front wing, where does that go I wonder...
- Hank
- Visitor
This is very important, if you have a 2005+ VVT jimny like mine with the button operated system you have to trick the 4wd controller. If you don't, even with the vacuum lines blocked off the light will flash and the transfer case will not activate because the system will think there's a problem. Either that or my vacuum system in the engine bay has a leak somewhere
The Hubs:
Step 1: Locate the switch cable to short out. Look under the fuse box next to the battery, directly under it there is a white connector. Below are some pictures of it from different angles. I disconnected it from the plug to make it easier to see on picture but you can see the connector right next to it as well. Really you only need the connector that goes to the main harness.
With that unplugged I just cut off the connector, stripped the wires, twisted them together, heatshrinked it and put on a load of white tape so I can easily find it if I ever need to go back at it.
Also, here's a glimpse at blocking off the vacuum lines:
If I can find some blanking plugs I'll blank off the manifold properly but for now I just have it running to the valve and it works fine
- yira
- Visitor
- yira
- Visitor
- yira
- Visitor
Found some helpful info in the "My Jimny" section, thanks Sergiu!Sergiu post=232046
...The next issue I had was related to the vacuum system and the 4WD controller, probably because I have a type 9 Jimny the 4WD controller was updated and expects input from the vacuum switch for both locking (closed circuit) and unlocking (open circuit), so shorting the switch would not work. Interestingly even so the transfer case would shift perfectly through all the position, but it messes up the light on the dashboard so you are stuck with memorising the transfer case position, not very good. Plugged the pipes going to the hubs and everything was back to normal...
Shorting the switch did not work on a Type 9 so my South American spec Type 7 could be similar. I'll give blocking the pipes a try and hope my vacuum system doesn't have other leaks. Worst case I'll have working 4WD with a slightly annoying flashing light.
- felipebaldasso
I'll sum my history:
Bought a Jimny 2009, the 4WD and 4WD-L was working as well - the 4L light was blinking (while using it) and I could change from 4WD-L to 4WD, but the 4L light keeps blinking (until I turn 4WD off).
Then, after reading this post, I did that short-circuit and it worked ALMOST 100%... Now I do can change from 4x2 to 4WD and 4WD-L, and I can change from 4WD-L to 4WD and 4x2... But as soon as I put on 4x2 again, the both lights start blinking no matter what.
Do you guys have any thoughts?
- Thank you received: 1761
- felipebaldasso
Here's why "The next issue I had was related to the vacuum system and the 4WD controller, probably because I have a type 9 Jimny the 4WD controller was updated and expects input from the vacuum switch for both locking (closed circuit) and unlocking (open circuit), so shorting the switch would not work."
