Genuine Catalytic Converter
- markyp2000
- Visitor
Busta wrote: My exhaust split just infront of the cat. I would normally have gone for one of the £70 ebay ones but as the car was still under dealer warranty I bought a slightly more expensive (but still non-genuine) one from euro car parts.
At about £105 I expected it to come with a heatshield, but it didn't, and retro-fitting the suzuki heat shield wouldn't have been easy. It hasn't caused any management issues though.
Euro car parts do hope your going to keep the invoice safe as it will possably fail the mot nex year
- i5jimny
- Visitor
- Thank you received: 210
Yes I removed the cat off the jimny and market the cat with a marker pen so the welder could line it up before i removed it.helijohn wrote:
dirtydogz wrote: I second that, get it welded and save your self some money, I've just had my cat welded for £20 and it's just passed the M.O.T.
Did you remove it or did the repairer do the teardown as well as the welding or was it done in situ??
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
- Johnniehec
- Thank you received: 56
dirtydogz wrote:
Yes I removed the cat for the jimny and market the cat with a marker pen so the welder could line it up before i removed it.helijohn wrote:
It's a common problem, mine split there, easy weld as it's sleeved.
John.
MOT next month so we'll soon find out! I've had lots of non-genuine cats before without trouble. Is the Jimny particularly susceptible to failing on emissions? I've got the old one I welded up on the shelf anyway.markyp2000 wrote:
- Tadpole
- Visitor
Paul
1999 T registered Jimny. Early G13BB SOHC engine.
- Thank you received: 332
On my car, (and my mates 2004) the no1 cat had disintegrated and some large parts flipped sideways and constricted everything. the powder and smaller debris from it travelled down and got stuck in cat 2 as well.
So I removed the no1 cat by cutting the housing open, cleaned it up, and weld it shut again. Little or no difference in speed and performance. still passed MOT here in Norway.
So next step was to change the no2 cat. Bought an aftermarket cat at our scandinavian Halfords called Biltema cost about 70£. they also had the weld nipple for the snesor.
Welded it intoo the exhaust system where the original was before. kept both lambda sensors in the same positions.Later i also changed the narrow pipe between the manifold and the no2 cat.
WOW the difference in performance and engine noises and everything.
Went from going up a steep hill in third gear high rev and max 80kmh to fifth gear 120kmh and still accelerating.
Still passes MOT. Sometimes during either long drives or cold weather or plunging into a cold puddle, the engine light comes on and says insufficient exhaust emissions something. Happened four times last year or so but I just reset the ECU and it's gone until the next time.
Paul4A wrote: Is the message here that Europarts quality is poor? I’m asking because I think ours may be blowing and they’re only a mile from my house. Having said that they’re charging £289 at the moment against approximately £70 on eBay. Having said that there’s several on eBay and hard to tell them apart. Some suggest lamda sensors and others not which I have no clue over. Advice welcome.
Paul
Yes. Some of what they sell is absolutely rubbish. I've returned so much because it either doesn't fit or just doesn't work, which they always take without a quibble but it's the grief.
I now only buy big branded stuff from them. Anything else has a question mark over it.
I had a garage fit a water pump to the Mrs old BMW with the instructions for it to have a metal impeller and not be rubbish. 20k miles later I find it was leaking and was Circoli from Eurocarparts.
If you want a good pattern cat, go to a local Motor Factors and pay a few hundred for it. Don't use Kwik Fit or Formula 1 who have Eurocarparts vans in and out all day.
- Thank you received: 1761
