Forum
Suzuki Jimny
Jimny Technical
Genuine Catalytic Converter
BigJimnyMeet 2024
i5jimny
Topic Author
Visitor
16 Jul 2013 21:59 #77298
by i5jimny
Been told today by garage doing crankshaft pulley that cat has a split in the pipe at one end. This was founf during safety check. They are saying that gen Suzi one is £450 and they are unsure about non gen as when fitting non gen cats to Toyotas they can throw up engine management lights. Just wondering what guys in the know think as I am going to try garage i bought car from to replace it as it was MOTd 2 days before I picked it up and I have only done about 200 miles since buying. Dont think they will stump up so need to know if I can go cheaper.
Dalby
Visitor
Thank you received: 177
16 Jul 2013 22:05 #77305
by Rhinoman
I've never had an issue with a pattern cat. A high-flow performance cat can give problems if there isn't enough back pressure for the EGR system to work effectively but on a Suzuki there is usually enough manifold vacuum so it isn't a problem.
i5jimny
Topic Author
Visitor
16 Jul 2013 22:08 #77309
by i5jimny
Thanks for that guys. Any ideas of best one to ho for and idea of price, my one is 57 plate.
Dalby
Visitor
i5jimny
Topic Author
Visitor
16 Jul 2013 22:18 #77311
by i5jimny
Yeah, been on there not long ago but 2 or 3 kinds and not sure which is best. If garage pays not a prob, if I have to pay then I will definitely be buying off there.
markyp2000
Visitor
16 Jul 2013 23:42 #77316
by markyp2000
Just get it welded dam site cheaper than a new cat
Thank you received: 210
17 Jul 2013 20:03 - 17 Jul 2013 20:04 #77371
by dirtydogz
I second that, get it welded and save your self some money, I've just had my cat welded for £20 and it's just passed the M.O.T.
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
i5jimny
Topic Author
Visitor
17 Jul 2013 22:49 #77400
by i5jimny
Good to know you can weld them but the dealer I bought Jimny from has agreed to replace cat with gen Suzuki item as well as crankshaft pulley so can't complain at that. Only bad point is I won't get the Jimny back till next week
markyp2000
Visitor
18 Jul 2013 07:13 #77406
by markyp2000
Take a look at the old cat and then the new jus to make shore it is genuine
Thank you received: 740
18 Jul 2013 09:12 - 18 Jul 2013 09:45 #77411
by Busta
My exhaust split just infront of the cat. I would normally have gone for one of the £70 ebay ones but as the car was still under dealer warranty I bought a slightly more expensive (but still non-genuine) one from euro car parts.
At about £105 I expected it to come with a heatshield, but it didn't, and retro-fitting the suzuki heat shield wouldn't have been easy. It hasn't caused any management issues though.
Last edit: 18 Jul 2013 09:45 by
Busta.
Thank you received: 260
18 Jul 2013 18:30 #77470
dirtydogz wrote: I second that, get it welded and save your self some money, I've just had my cat welded for £20 and it's just passed the M.O.T.
Did you remove it or did the repairer do the teardown as well as the welding or was it done in situ??
Do it right - use Hammerite
When the blue light is flashing I am kidding.
Forum
Suzuki Jimny
Jimny Technical
