BigJimnyMeet 2024
Re:"Jimny Lean"
- tommy
- Visitor
27 Mar 2013 20:11 #67088
by tommy
"Jimny Lean" was created by tommy
Hi there,just bought my first Jimny at the weekend there and have noticed that it leans to one side.
It has has been fitted with 2" ES3000 shocks and springs.
My question is with regards to the spacers you buy,do you buy for front and back as it seems to lean from both?
Thanks Tommy.
Thanks Tommy.
- markyp2000
- Visitor
27 Mar 2013 20:44 #67093
by markyp2000
Replied by markyp2000 on topic "Jimny Lean"
Just the front spring spacer
- tommy
- Visitor
27 Mar 2013 20:52 #67095
by tommy
Replied by tommy on topic "Jimny Lean"
Cheers guys,its just it looks like its leaning at the back to?
- markyp2000
- Visitor
27 Mar 2013 21:12 #67100
by markyp2000
The front will pick it up at the rear trust us we know lol
- trevorjd
- Visitor
28 Mar 2013 07:19 #67124
by trevorjd
Replied by trevorjd on topic "Jimny Lean"
Bits for vits do a single spacer for the front drivers spring for about £20
Sorts it out a treat because I've just done mine
Very fast postage from them aswell
- jonesyba420
- Visitor
16 Apr 2013 20:24 - 16 Apr 2013 20:39 #68839
by jonesyba420
Replied by jonesyba420 on topic "Jimny Lean"
I have this issue to, if your looking from the back it noticabley leans to the left! Ive looked on bits for vits at the spacer your talking about and noticed you can get a set of 4 which boasts a 1.25inch lift. would fitting all 4 still leave me with the good ol jimny lean?! mines not lifted either.
Last edit: 16 Apr 2013 20:39 by jonesyba420.
- markyp2000
- Visitor
16 Apr 2013 23:09 #68849
by markyp2000
It would still lean i think
- jonesyba420
- Visitor
17 Apr 2013 10:50 #68870
by jonesyba420
that was my thinking to, what would i then have to do to sort the lean if i fitted all 4 spacers? another question regarding the spacers, when you fit a lift kit its longer springs and shocks but in the case of these 1.25inch spacers your effectively making the spring longer but not the shock, does this cause any issues regarding the shocks as they are still stock?
they also do the rear shock extension/re-locators which look and sound interesting but do these make any difference on a stock jimny?
- Thank you received: 82
22 Jan 2019 21:45 #201454
by Dirtbird
Heavy Duty Transfer Box Brackets, 2-inch Black Raptor lift kit, caster adjusters, Rust removed and stich welded new sections. Galvanised Chassis. Body,Engine,transmission swap. Anti Rollbar Roll / Sway Bar / DAVES ARB disconnect kit.Osram Night Breaker Head light mod and white 501 led side lights.
Replied by Dirtbird on topic "Jimny Lean"
OK lads this is the Jimny Lean question again but in the right thread . Question is how many spacers and how much additional lift on the drivers side to balance it out?
Looking at these but open to recommendations www.jimnybits.com/jimny-superpro-15mm-spring-spacer.html
This is how much sag is in the system.
22 Jan 2019 22:52 #201466
by kirkynut
Replied by kirkynut on topic "Jimny Lean"
I'd go with a 15mm spacer. I think I put a 25mm one on mine and it reversed the lean to the other side!
It evens out when I get in I think!
22 Jan 2019 23:03 #201468
by Dirtbird
Kirkynut thanks 15 it is .
02 Feb 2019 18:34 #202385
by Dirtbird
kirkynut the 15 spacer still didn't sort the problem so I said id have a look this morning . 6 pm downed tools. In effect the PO had the long springs on the front and the longest of them on the passenger side and the short springs on the back. Please tell me that is wrong . I took them all off and installed my jimny bits springs longest on the rear and the longest one of those on the driver side. Shorts up front is that correct? Please tell me it is .
Time to create page: 0.149 seconds
