BigJimnyMeet 2024
How to fit a 2"or 3 spring lift.+Wiring spotlights
- Richard666
- Visitor
24 Jun 2013 21:26 #74980
by Richard666
Replied by Richard666 on topic How to fit a 2"or 3 spring lift.+Wiring spotlights
That would be very useful
- Thank you received: 210
24 Jun 2013 22:07 - 24 Jun 2013 22:07 #74995
by dirtydogz
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Replied by dirtydogz on topic Fitting a 2"or 3" spring lift.+ Wiring spot lights
Jimnybits 2"lift £336 +rear shock repos £30 + correction bushes £106.80.
www.jimnybits.co.uk/shop/jimny/suspension/cat_171.html
2002 JLX Soft Top
Last edit: 24 Jun 2013 22:07 by dirtydogz.
- GuardianAngel
- Visitor
28 Oct 2013 16:30 - 28 Oct 2013 16:32 #88337
by GuardianAngel
Replied by GuardianAngel on topic How to fit a 2"or 3 spring lift.+Wiring spotlights
Last edit: 28 Oct 2013 16:32 by GuardianAngel.
- Jimnyash
- Visitor
29 Oct 2013 08:01 #88433
by Jimnyash
Replied by Jimnyash on topic How to fit a 2"or 3 spring lift.+Wiring spotlights
That's the relay and as far as I know, it's a standard 5 pin automotive relay (at least that's what I asked for and got when wiring my spots).
03 Nov 2013 14:36 - 03 Nov 2013 14:52 #89156
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic How to fit a 2"or 3 spring lift.+Wiring spotlights
Sorry Guardian Angel I know it's a bit late, but as Jimnyash said, yes it is a wiring diagram of a relay.
If you buy a set of the ring spot light you will get a 4 pin relay and fitting kit in the box.
www.halfords.com/webapp/wcs/stores/servl...-1_categoryId_272451
2002 JLX Soft Top
Last edit: 03 Nov 2013 14:52 by dirtydogz.
The following user(s) said Thank You: GuardianAngel
03 Nov 2013 21:12 #89239
by jimkyx
Replied by jimkyx on topic How to fit a 2"or 3 spring lift.+Wiring spotlights
4 pin is a single pole relay
5 pin is a change over relay
You can use a 5 instead of a four but not the other way round.
Best price for these relays is Maplin.
- GuardianAngel
- Visitor
04 Nov 2013 14:33 #89319
by GuardianAngel
Thanks for the info everyone
- Tommo
- Visitor
05 Nov 2013 23:28 #89573
by Tommo
Replied by Tommo on topic How to fit a 2"or 3 spring lift.+Wiring spotlights
- Dean1994
- Visitor
06 Jan 2014 13:01 #99355
by Dean1994
Replied by Dean1994 on topic How to fit a 2"or 3 spring lift.+Wiring spotlights
Hi I've just bought the same spot lamps as you, just wondering how you mounted the bar on the roof as I have a soft to Jimny too?
- Dean1994
- Visitor
06 Jan 2014 13:04 #99357
by Dean1994
Ahh just seen your link on how you mounted them think I will do the same cheers!!
- Lukeavb
- Visitor
23 Aug 2014 18:05 #122606
by Lukeavb
Replied by Lukeavb on topic How to fit a 2"or 3 spring lift.+Wiring spotlights
Will I need new bolts for my 3" or can I re use the old ones where can I get new bolts if I will need new bolts?
- Tommy-Boy
- Visitor
30 Mar 2016 17:43 - 30 Mar 2016 17:46 #164655
by Tommy-Boy
Replied by Tommy-Boy on topic spring lift.+Wiring spotlights
Hi Guys
could someone clarify that i'm understanding this correctly in regards to wiring a light bar onto my little Jimny
This is my understanding of the relay diagram as posted in this post from dirtydogz
www.bigjimny.com/index.php/forum?view=topic&catid=7&id=45978
I'm just not 100% that i am understanding the diagram correctly.
However the light bar is fitted and when hooked up to my jumper pack it burns your flippin eyes out!! LOL
- Negative (-) wire from the light bar to a sutibale earth point
- Pos (+) wire from the light bar to pin 87 on the relay
- Pin 85 on relay to "Acc" on the switch
- Pin 30 direct to the battery Pos (+) through a sutible fuse (15Amp)
- Pin 86 daisy chain to pin 30 with a second bridge wire to the negative (-) switch terminal, even though this is live (+) ?
- Pos (+) from the switch to the red wire on the headlight plug
Last edit: 30 Mar 2016 17:46 by Tommy-Boy. Reason: cant spell for shit
Time to create page: 0.142 seconds
