BigJimnyMeet 2024
Nearly stalling on idle - any tips please
- ramshackle
- Visitor
21 Apr 2016 15:53 #165579
by ramshackle
Replied by ramshackle on topic Nearly stalling on idle - any tips please
I tipped a bottle of Millers petrol Eco max fuel cleaner in to the tank, filled up with motion lotion and the fault cleared up after about ten miles. The car also ran much better..
21 Apr 2016 18:40 #165592
by Busta
Replied by Busta on topic Nearly stalling on idle - any tips please
You joined the forum to revive a 4 year old post to promote a fuel additive that couldn't possibly clean the part that causes the (very common) idling issue?
- Syfon
- Visitor
18 May 2016 15:39 #166963
by Syfon
Replied by Syfon on topic Nearly stalling on idle - any tips please
Does anybody tried to clean IAC valve with some cleaner without dismantling it from throttle body? Service manual says that IAC should be cleaned only with compressed air, so I tried but it does not make any difference with idle stalling problem.
- shakennstirred
- Visitor
05 Oct 2017 17:22 #184882
by shakennstirred
Replied by shakennstirred on topic Nearly stalling on idle - any tips please
Have this problem on my 02 jimny.
hopefully the info here will help sort it.
- Sackgirl09
- Visitor
27 Apr 2018 19:50 #192231
by Sackgirl09
Replied by Sackgirl09 on topic Nearly stalling on idle - any tips please
Im having a similar issue - except mines idling bad but when i take off it doesnt want to accelerate (basically no go) untill the temp gauge is half way then its fine with acceleration but idle is still crummy. But im more worried on it not wanting to go - any ideas?
We cleaned the iac, carby. Also changed spark plugs, coils, leads umm there was a sensor replaced earlier as had engine light on.
Now there are no error codes as took it in for a scan.
Can anyone suggest what mine could be?
29 Apr 2018 21:18 #192284
by kirkynut
Replied by kirkynut on topic Nearly stalling on idle - any tips please
Check all vacuum lines. They're the small diameter pipes in the engine bay that go to the inlet manifold and the 4wd vacuum system, which is near the battery.
- Silvervixen
- Visitor
08 Jan 2019 21:13 #200211
by Silvervixen
Replied by Silvervixen on topic Nearly stalling on idle - any tips please
I've got the same issue with an 06 Jimny. Changed crank position sensor, MAF sensor, battery, spark plugs and leads, throttle body cleaned as clogged. Also Cataclean added to fuel tank and taken for long run. No EMS lights and diagnostics not showing fault codes. Am at a loss and it's getting worse. Was intermittent, now drops revs to around 400rpm EVERY time I stop. Also hesitates on acceleration but intermittently. Starts up ok but messes around having warmed up or after stopping and cooled down for a while. HELP PLEASE!
08 Jan 2019 21:17 #200212
Replied by mlines on topic Re:Nearly stalling on idle - any tips please
To check for a leak, carefully spray a bit of easy start around suspected leaking pipe. If revs pick up then check for splits
Time to create page: 0.140 seconds
