BigJimnyMeet 2024
Re: instrument panel removal
- tonyward
- Visitor
10 May 2011 17:39 #16152
by tonyward
Ok,I recently scoured the web for kingpin replacement help and came across this site!
After the invaluable help I got from a forum topic which included very helpfull photos I decided to repay the debt with one of my own.
Another helpful topic helped me replace the instrument panel "backlight" bulbs and I decided to show you a simple picture by picture walkthrough (as the aforementioned post had no pictures)
So...picture of the 2 screws to be removed (stubby phillips screwdriver as its a bit tight)
instrument panel removal was created by tonyward
Attachment 080520111193.jpg not found
- tonyward
- Visitor
10 May 2011 17:42 #16154
by tonyward
Then simply pull the panel towards you,the best grip for me was just above the clocks,it feels like it wont give but they are just pushfit clips and they do eventually give
Replied by tonyward on topic Re: instrument panel removal
Attachment 080520111194.jpg not found
- tonyward
- Visitor
10 May 2011 17:43 #16155
by tonyward
Picture of the removed front
Attachment 080520111195.jpg not found
- tonyward
- Visitor
10 May 2011 17:46 #16158
by tonyward
And picture of exposed instrument panel
Attachment 080520111196.jpg not found
- tonyward
- Visitor
10 May 2011 17:49 #16160
by tonyward
The panel securing screws,2 on the left,2 on the right,left side shown.
A medium length philips is needed to reach,a magnetised one would be best to make sure you dont drop the screw into the wiring behind the steering column.
Attachment 080520111198.jpg not found
- tonyward
- Visitor
10 May 2011 17:51 - 10 May 2011 17:53 #16161
by tonyward
Then pull the panel towards you while twisting upwards as the connectors are at the top and need to be removed,the connectors have a locking grip (which is behind them on this picture) simply squeeze and pull down
Attachment 080520111199.jpg not found
Last edit: 10 May 2011 17:53 by tonyward. Reason: to put additional text in
- tonyward
- Visitor
10 May 2011 17:58 #16163
by tonyward
Removed panel showing all bulbs (larger center 3 are illumination bulbs)(smaller outer bulbs are ignition,oil etc etc),
assembly is the reverse of removal,the cover required a little bit of squeezing to get past the steering wheel wihich is best if kept at 12 o'clock position.
And thats it!
Apolgies if this sound like the dummies guide to panel removal but its my first time at this.
Hope this helps someone.
Thank you!
Attachment 080520111200.jpg not found
And thats it!
Thank you!
- Thank you received: 210
10 May 2011 18:48 - 10 May 2011 19:00 #16170
by dirtydogz
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Replied by dirtydogz on topic Re: instrument panel removal
Thank you Robert and Welcome to the BIG JIMNY website.
DIRTYDOGZ
DIRTYDOGZ
2002 JLX Soft Top
Last edit: 10 May 2011 19:00 by dirtydogz.
- renard38
- Visitor
11 May 2011 16:56 #16203
by renard38
Replied by renard38 on topic Re: instrument panel removal
very interesting, thanks
- Shagnasty
- Visitor
13 May 2011 13:01 #16275
by Shagnasty
Replied by Shagnasty on topic Re: instrument panel removal
Hmmmm. Any chance you could put LEDs in place of the normal bulbs? That way you could have funky colours, and more importantly they'd last a lot longer.
- Thank you received: 34
13 May 2011 13:38 #16278
by ooky_123
Former owner of Little "Ooky", who has now started a new life in Shetland
Replied by ooky_123 on topic Re: instrument panel removal
you could put LED's in place as long as you can get them in a standard fitment.. or you could remove and re-wire the connectors but its a lot of work
- tonyward
- Visitor
13 May 2011 16:42 #16285
by tonyward
when I checked and replaced the bulbs they all seem to be the "push-in" type.
A bayonet type twist to remove the holder and a gentle pull removes the bulb from the holder.
the bulb has two wires coming out which are then folded either side of a glass fitment to ensure good contact, I dont see why you couldnt just push an LED in place (Do LED's run on 12v d.c.?)
Time to create page: 0.133 seconds
