BigJimnyMeet 2024
× A place for general chat about the Jimny. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
cb's.... where to mount.
  • biggaz
  • Visitor
  • Visitor
18 Jan 2011 10:33 #9913 by biggaz
cb's.... where to mount. was created by biggaz
Ok so now realise a cb is a handy tool lol!
A mates got one i can have cheapish so... where have you mounted yours and what type of aeriel do you have, this ones coming with a mag mount but do you leave it mounted on roof or what about the wires etc?
Any tips on what setup you have would be cool. Thanks again gaz.
18 Jan 2011 11:31 #9915 by jonplace
aye great little bit of kit a CB !
go to birtly CB services (google them) for about £65 quid you can get nice little TTI unit 40ch with ariel etc. as yours is a tin top you could just go for the magnetic pad and stick ariel on roof when in use like taxis do
I've mounted CB under ciggy tray. remove ciggy tray and throw it at next doors cat. bend / cut a bit metal to make a bracket that slides into fag tray and secure to that, pics of mine
dead easy to wire up
hope this helps :)
18 Jan 2011 11:32 #9916 by jonplace
i'll try and get a pic later today of the bracket etc etc
means going outside :(
  • biggaz
  • Visitor
  • Visitor
18 Jan 2011 12:03 #9917 by biggaz
Replied by biggaz on topic Re: cb's.... where to mount.
Dont worry bout bracket mate, thats spot on.
With an aerial for the roof, would you just diconnect the wire to aerial when not in use as i wouldnt want it lying around lol. may change to a fixed on like yours later as id prefer to wire it in permanant and hidden wires etc.
I was going to go to birtley CB mate as you said but a friend said he had a Midland one he'd never used, 100 channel? says it was around 100 quid when he bought it and i can get it off him pretty cheap so see what its like! If no good i'll head to birtley.
thanks again gaz.
18 Jan 2011 12:55 #9920 by mlines
Replied by mlines on topic Re: cb's.... where to mount.
Andy Whalley has just emailed in these pictures for you to see...
Attachment cb mount 003.jpg not found
Attachment cb mount 002.jpg not found
Attachment cb mount 001.jpg not found
The following user(s) said Thank You: biggaz
  • biggaz
  • Visitor
  • Visitor
18 Jan 2011 13:37 #9922 by biggaz
Would never have thought of putting it there, thanks for the pics!
18 Jan 2011 14:08 - 18 Jan 2011 14:09 #9923 by andyw
Replied by andyw on topic Re: cb's.... where to mount.
Thanks Martin,
I used ali, because I had it lol, but as long as you shape it to the headlining should be fine, if you take the light off you,ll see theres two screws, and a big hole in the lamp base.
I just made the hole in the metal about the same size and drilled two hols to suit the two in the lamp base. I found two bolts the same thread and cut them down so they did'nt hit the roof.
It's been up there for a few years with no probs, powered straight from the batt with inline fuse, in the bulkhead via the gromit, then up the side of the winscreen pillar hidden behind the trim. I use a mag mount twig and have been happy with it .
hope that helps
Andy
Last edit: 18 Jan 2011 14:09 by andyw.
18 Jan 2011 16:22 #9927 by Johnniehec
At the risk of showing my age, do you still need a licence for a CB?:blush:
  • Keefe
  • Visitor
  • Visitor
18 Jan 2011 17:20 #9928 by Keefe
Replied by Keefe on topic Re: cb's.... where to mount.
Johnniehec wrote: At the risk of showing my age, do you still need a licence for a CB?:blush:
No you don't.
Great place to mount one as well, in the 'roof space'.
That's where mine's going to go.
K :)
  • vitara_mad
  • Visitor
  • Visitor
18 Jan 2011 17:34 #9929 by vitara_mad
Replied by vitara_mad on topic Re: cb's.... where to mount.
mine is in the same place as jonplace but i also like that roof mounted idea
  • biggaz
  • Visitor
  • Visitor
18 Jan 2011 18:01 #9931 by biggaz
Yeh it is a nice idea, thanks again!
Got a CB now so just need to get a bracket sorted to mount it, came with a mag mount and home power supply which i'll not use.
Will be wiring straight to car not via cig lighter plug i think.
Its a midland 80 channel
Attachment IMAG0158.jpg not found
Never been used hardly so spot on.
  • paulnb57
  • Visitor
  • Visitor
18 Jan 2011 19:10 #9943 by paulnb57
Replied by paulnb57 on topic Re: cb's.... where to mount.
I use one of these
Usable inside or outside the truck, esp good when winching, usually run from a 12v ciggy power supply cos it takes 10 pencell batteries!! No screw holes or bracketry.
Range is OK in an off road convoy............all I need.....
Cost a fiver off ebygumbay
Paul
Time to create page: 0.186 seconds
Powered by Kunena Forum
