Which pipe or pipes do I block up
I just popped out to the garage and took a clearer shot as below. It's the pipe off the T piece that would go down to the hard pipes to provide the vacuum, so now it's sucking on the bolt.
By doing it this way you can leave the electronics as they are and as long as there's no vacuum leak from the pipe off this T piece that appears to go via 2 other T pieces to the inlet of my non VVT 2000 twin cam. Yours is VVT, so it might be a slightly different layout.
Then rip off everything on the axle and use a bit of plastic pipe to link the two parts of the steering knuckle/hub to stop water ingress, as per my guide photos. I forget where mine came from but wiper squirter pipe will likely be right and can be obtained easily from Halfords, motor factors or the internet.
Tinbox wrote: Thanks the new picture is clearer. Have you plugged both tubes with screws. My manual hubs should arrive on Thursday so weather permitting I’m going to have a go at sorting this out once and for all!!!!
I only seemed to have one to block. I have no vacuum leaks.
- Thank you received: 584
Tinbox wrote: Oops!!! now I’m confused I’ve blocked both pipes and the green light is still flashing. Any ideas?????
Short out the switch, there must still be a vacuum leak.
There are two electric solenoid vacuum valves. Both should route atmosphere to the hubs when off (via a little filter), and block the vacuum line.
When either is activated, it changes over to route vacuum to one side of the hub, and atmospheric pressure pushes the hub over from the other side through the non-activated valve.
If the disengage solenoid valve seizes up, it sticks so that the vacuum line connects to atmosphere, and you can never build up a vacuum in the tank, or activate the vacuum switch even if the engage solenoid valve is working.
Without seeing photos of your pipes I'm not sure what you have on your car. Fooling the electronics is fine for the light but make sure you don't have a vacuum leak.
4 x 4 capabilities again without your help
If you are going to be hopping between tarmac and non-grippy surfaces (like going between green-lanes), it is ok to leave the manual hubs in 4x4 and just put the transfer box into 2wd and back to 4wd as needed. The front prop, diff and half-shafts will be driven by the wheels, leading to slightly poorer fuel consumption. No damage will occur however (as long as you put it in 2wd for grippy surfaces) and it saves you getting in & out of the car at every surface change. At the end of the trip, flick the hubs back off for the drive home
The reverse of this can be used to get 2wd low-box, which can be useful for maneuvering trailers
