BigJimnyMeet 2024
Going into limp mode? Power loss?
- invincible
- Visitor
04 Sep 2019 09:16 #213114
by invincible
Going into limp mode? Power loss? was created by invincible
My jimny is cutting out when driving, feels like no power, then all of a sudden pulls again. Cut out this morning on way to site for longest time, busy a66 and no pull offs.I have a 1.6 that I desperately need to fit but think I need to find out the problem on this 1.3 before fitting as the fault will just follow? Im thinking electrical, perhaps a wire earthing? Guy in garage put snap on, diagnostic computer on it and it showed nothing? I need to get to a railway station later a prob wont make it. Maybe this engine is just about to die, any ideas on what electrical parts I could check, id be well grateful. Cheers in advance, liam
- Thank you received: 1759
04 Sep 2019 09:46 #213121
Replied by Lambert on topic Going into limp mode? Power loss?
If it's not giving a code and is intermittent I would suggest coil packs and leads. Most other things will give you a code.
- Thank you received: 583
04 Sep 2019 11:16 #213125
by facade
Replied by facade on topic Going into limp mode? Power loss?
Could be crankshaft position sensor, these don't show a code, but the engine usually stops for a few minutes until it cools down.
- invincible
- Visitor
06 Sep 2019 13:03 #213205
by invincible
Replied by invincible on topic Going into limp mode? Power loss?
thanks guys, coil pack and leads, where would i find these on engine i,ll try and swap em then, and crank shaft sensor will be in the engine so ok when i swap in the 1.6 then i,m thinking? cheers Liam.
- invincible
- Visitor
06 Sep 2019 13:07 #213206
by invincible
No eBay APP ID and/or Cert ID defined in Kunena configurationnew ones of these then u rekon lambert? cheers Liam
06 Sep 2019 13:17 #213208
That's the ones. They sit under the black cover on the top of the motor. Dead easy to swap.
- GF68
- Visitor
07 Sep 2019 07:33 #213245
by GF68
Replied by GF68 on topic Going into limp mode? Power loss?
Sounds exactly like the issue I had and it was coil pack/leads that fixed it.
I really struggled to find leads that were a good fit after market. So in the end but the bullet and bought genuine Suzuki leads at circa £50! Coil pack much easier to find, bought one locally and used it to identify which actual pack was faulty.
Note I ended up with slightly wrong ones from amazon despite them saying would fit, needed vin number to get exactly what was needed. But as others have said it is an easy job to do.
- invincible
- Visitor
07 Sep 2019 07:34 #213246
by invincible
thanks lambert , so the above ones are correct, its looks like they fit all the engines. my 1.6vvt swift engine will have em in, i,m thinking try the 1.6 first eh any thoughts folk
07 Sep 2019 08:30 #213249
If you have a set on the 1.6 it would be economical to swap those in first and confirm the fault is rectified and then when you swap the motor in get new ones for the 1.6.
- invincible
- Visitor
07 Sep 2019 21:09 #213275
by invincible
yeah good thinking bat man! a damn good tip idea lambert, cheers bud , i,ll try that. spot on .
- invincible
- Visitor
10 Sep 2019 14:30 #213357
by invincible
Cheers gf, ive started the 1.6 engine swap today so hope the fault doesnt follow. If it starts!! Did you find out that a coil pack was faulty?
- GF68
- Visitor
10 Sep 2019 14:49 - 10 Sep 2019 14:50 #213359
by GF68
Yes, in the end, tracked it down to a single faulty coil pack that was breaking down when hot. If you lived closer I would lend you a couple of spares that I now have so you could do the same!
Last edit: 10 Sep 2019 14:50 by GF68.
Time to create page: 0.114 seconds
