Seat belt buzzer termination? (Gen 4)
This disables the seat belt alert, specifically where you carry items on the front passenger seat.
I do not have the Gen4 manuals but I would assume it has a similar facility
- CC Baxter
- Visitor
Chris
- Andy2640
- Visitor
CC Baxter wrote: This one's for you Andy, pull this 4 pin plug and no more seatbelt warning on the driver's side (which I think is what you were after). Trouble is no more heated seat either, four wires two for seat heater two for belt alarm. I will investigate further in the future (seat out) but for now this is good enough.
Chris
That is mega appreciated CCB! Thank you mate.
I dont use the heated poo cooker anyway, so no worries there.
Great stuff, cheers!!
- CC Baxter
- Visitor
- Andy2640
- Visitor
Thank you CCB!!
- Thank you received: 319
Have added the info to the wiki
- CC Baxter
- Visitor
I took the seat out for a good rummage around. Disconnect the 4 pin white and the yellow SRS plugs. Torx 40 for the four seat bolts and pop the seat out.
Always be careful with airbag wiring, just think of the system as an unexploded bomb
and your on the right track. Pic1 shows the thumb slider on the SRS connector. Pic2 is the seat belt alarm plug to pull, pic3 is the end result.
Chris
- Thank you received: 1755
- CC Baxter
- Visitor
Chris
- Thank you received: 329
We are not a member but still most rules apply. Outside we do not have a vote though..
- CC Baxter
- Visitor
Chris
CC Baxter wrote: Sorry Lambert for vague and incomplete description. The SRS plug ( and adjacent 4pin white plug) are reconnected when you put the seat back in. Airbags all work as they should. The seat belt reminder is classed as a convenience feature and a known free for all to disable. Hope this clarifies things a bit.
Chris
Ok. Its just it read like you were disconnecting the srs permanently.
