Camping in the Jimny. Roof Top Tent and kit tried
- GeordieJimny
- Visitor
- Bill Portland
- Thank you received: 77
GeordieJimny wrote: Can't see any limit in the owners manual
Exactly. All this talk about roof limits on the gen 4 is simply wrong. There is no stated limit unless you use Suzuki's own roof bars (which appear to be much weaker than any others on the market).
- Visitor
GeordieJimny wrote: Can't see any limit in the owners manual but yeah I don't disagree, everything's a risk. Interestingly, would insurance pay out of you put a Jimny on it's side off-roading, regardless of roof load?
That will all depend on your insurance which is another can of worm's
- Thank you received: 552
Agree 100% The reference to a 30kg limit is for the GEN3 roof rails, it clearly states "roof rails". No other limit or recommendation is given for a generic roof load in any other section of the manual supplied with the vehicle. Don't know what it says in the GEN4 manual, but if you bin the standard roof rails on a GEN3 you are limited by the load recommendation of your chosen replacement roof rack.
Re Insurance :- it makes sense to tell them of any modifications, be it a tow bar, suspension, tyres or the fitting of an aftermarket roof system etc. Once you have told them I doubt they will careless, they will have bumped your insurance premium to cover the extra "risk".
If you topple the vehicle "off roading" unless your insurance specifically covers the vehicle for this type of use I doubt you will be covered.
- Thank you received: 479
What if you are Greenlaning surely that is still classed as a public high/byway so would insurance cover it? I know it is different if you use a private off road course.
That's a good point. On paper I believe a byway is classed as a public access road, so it should be covered. However you should read the small print of your policy and if any doubt still exists ask your insurance company. You can get grey areas, for example some policies excluded 4x4 events. So if a group of you plan a day out on a byway is that an event?
So check your policy meets your needs.
Pity it's boring reading
- iawra
- Visitor
I’m just wondering if for a low profile and reduced weight setup, the tent can be mounted directly to two 1345mm slat add-on kit (ref RRAG1345) and leave aside the two tent’s mounting channels. Then use the lowest legs (ref LASS101) for an even lower profile.
If possible, the only downside would be that removing the tent with the load bars won’t be as easy as with the quick release mount kit, but still only 4 screws.
- iawra
- Visitor
The idea is to mount permanently the base tent to the rack slats, I think it will barely fit between side profiles, the mount would be without tent mounting channels or mounting kit. And make use use the 120mm rack legs instead of the proposed 130mm for the Jimny racks.
Of course the antenna would have to be removed and placed elsewhere.
What do you think?
- GeordieJimny
- Visitor
So the lightest and perhaps strongest 2 bar option would be front runners. I think they’d work well.
In the end I went with the 3/4 rack as it will offer more flexibility longer term. Plus I wanted to try the quick release tent brackets but I’ve changed those to the standard ones.
On The diagram you posted I’m not sure you’ll save much weight the slats are really lightweight. It’s going to be marginal. I’d recommend focusing on making it more aerodynamic as I’m seeing better results from reducing the drag and height of the tent on fuel economy and also driving experience.
People will say it’s not wise but even the full rack with the tent would work, I’m seeing plenty heavier setups online now. Text boxes for example. Still, lighter the better imho.
- GeordieJimny
- Visitor
I couldn’t figure out how to edit the original post so I’ve created one on my blog geordiejimny.com/a-detailed-guide-to-suzuki-jimny-camping that I’m updating as I try new ideas out. For example I’ve just made a bracket to have a quick release fitting for a telescopic ladder. Will be adding that to the guide later today.
- AlexK
- Visitor
Obviously everyone is free to do with their Jimny as they see fit, but I personally think people should be forewarned.
- Bill Portland
Suzuki have also said that underbody sealing will 1) invalidate their warranty and 2) not invalidate their warranty.
