G16B 1999+ Baleno engine in a 1999 Jimny
- Thank you received: 328
If someone is better at searching please link here.
have to do:
- adapter on the gearbox (my own design)
- oil pickup fix -weld job using the G13BB pipe with the G16 top end and flange.
- engine mount fix (right side is ok?) -weld job moving the mount 2.5cm on the g16
- bolts trickery as i have not sourced the outer ones at bottom gearbox flange. -weld or inserts or lathe job.
- reuse G13BB generator and pump brackets
- reuse G13BB water pipes
- reuse G13BB intake and exhaust manifold.
- use G16B injectors
- reuse G13BB engine wiring loom and ECU.
- doing the clutch and belts.
- removing oil filter angle mount,
- Reuse the stud from the G13BB as the m13a stud is too short for the G16B.
blank off the crank sensor at the oil pan?
I thought that we did not have to swap the cam, correct?
anything else?
- MadsV
- Visitor
I have also done this before with putting the 1,3 cam in the g16 head, no problem
- Rabid Rhino
- Elite Member
www.bigjimny.com/index.php/forum/8-my-ji...r-norwegian?start=96
there is MadsV's good pictures in his thread.
- MadsV
- Visitor
what steering pump and generator bracket to use?
Jimny one doesn't fit, but will the baleno clear the frame rails?
- MadsV
- Visitor
- Rabid Rhino
- Elite Member
Also here's a handy link of a build without an adapter plate
www.bigjimny.com/index.php/forum/7-jimny...ut-using-adapter-kit
Which adapter should you use ?
Rabid Rhino wrote: What about a pre 1999 G16B ? (I have a 1996)
The pre 1999 does not have the same ignition system so you will have some wiring issues.
The 1996 baleno engine also have a mechanical distributor that protrudes into the firewall of the jimny.
Vitara (not GV) engine is a better choice then if you can find an early one.
I use my own adapters originally designed for SJ. Sold only in Norway.
- Rabid Rhino
- Elite Member
Distributor Adapter designed for SJ: Who makes them ? DG Tuning ? Moes Suzuki Service ?
- MadsV
- Visitor
