BigJimnyMeet 2024
More expense.
20 Feb 2019 20:54 #203565
by adrianr
About Wee Jimmy : www.bigjimny.com/index.php/forum/8-my-ji...-first-jimny?start=0
Replied by adrianr on topic More expense.
Well done!
- Visitor
20 Feb 2019 21:09 #203567
Replied by Daniel30 on topic More expense.
Good news, fingers crossed
- Thank you received: 1761
21 Feb 2019 05:27 #203571
Replied by Lambert on topic More expense.
Thanks.
She is back on the road which is good but I'm not sure about the thermostat. It's a circoli one and does cross reference correctly along with a fiat and a couple of other vehicles but somehow I'm not happy. It wasn't as tight a fit as the original but sufficiently close to seat without a gap and to seal. I oriented it correctly with the bypass hole to the top. It was new in box. It's just that now she's taking longer than expected to warm up and isn't really running warm enough in general driving but then is warning up and cooling down quite quickly? To quantify the above statement. Previously from cold she was at 85 ish within a mile and a halfand would idle at that for a few minutes while collecting my passenger, now on the same journey she's at 75 and climbs to 83 while waiting. Then on the return journey she wouldn't get to more than 91 if I had to sit in traffic. Now she varies between 70 and 93 depending on traffic but as soon as I start to move the 90+ drops very quickly? I would have expected to see the temperature climb a little quicker and maintain around thermostat opening within a couple of degrees not be varying 10 degrees either way?
21 Feb 2019 06:04 #203574
Another thought. It's not inconceivable that the better designed impeller blades on the new pump could have a noticeable effect on speed at which the temperature drops? But that shouldn't have a bearing on the actual operating temperature just how well it's controlled?
- Thank you received: 305
21 Feb 2019 08:57 #203577
by sniper
Replied by sniper on topic More expense.
The temperature in normal use will have a "window" of operation. This window has a number of variables........
Static air temp
Barometric pressure
Humidity
Cooling air flow from the fan
Cooling air flow from forward movement
Fuel quality
Coolant quality
Coolant flow
Coolant pressure
Air/fuel ratio
Ignition timing
Under bonnet temperature
Engine oil quality
Engine load (rpm / torque load)
So many variables that it is very difficult to actually find a "normal" point of use.
Combustion is a very fickle process and can deliver vastly different temperatures with tiny changes in parameter.
The new pump / thermostat / flush / coolant change should be enough to move that window down the temperature range and change the system enough for you to notice a difference in how the car feels, in use.
On a performance engine, those changes would be enough to need a session on the rollers. The "tune" would need fine adjustment to deal with the changes in block temperature. A cooler engine generally means more power can be had.
sniper
Static air temp
Barometric pressure
Humidity
Fuel quality
Coolant quality
Coolant flow
Coolant pressure
Air/fuel ratio
Ignition timing
Engine oil quality
sniper
21 Feb 2019 09:23 #203579
I appreciate all that and if it were a matter of 2 or 4 degrees I would be fine with it. However a running temperature drop of between 10 and 12 degrees is significant and not just a tolerance issue. Something is out of whack, the thermostat being a prime candidate
21 Feb 2019 19:01 - 21 Feb 2019 19:01 #203601
by adrianr
It has to be the thermostat.
I know it’s a mission - I think I would be taking it out and making doubly sure it is the correct one and fitted properly. It is possible to fit it the wrong way around? You did say you weren't happy with it not being as snug.
Not saying you haven't fitted it properly Lambert, just thinking about 2 years back when I had to have three goes at getting my daughters mk4 golf replacement thermostat to seat properly so it would hold temp. Thankfully it was easily accessible but was a real head-scratcher for me. First time I have had trouble doing a thermostat.
Good luck.
Good luck.
Last edit: 21 Feb 2019 19:01 by adrianr.
21 Feb 2019 19:08 #203602
The more I have used it today the more and more I have been thinking it's behaviour is like it doesn't have a thermostat. Except i know for a fact that I put one in. I have a genuine one to collect tomorrow, after that it's getting a box of matches and a gallon of petrol!
21 Feb 2019 19:14 #203603
by sniper
Don't get frustrated mate, you'll find the solution without the need for pyro......
I'm having a mare with silly suspension problems, just enough to spoil my enjoyment but not enough to stop use.
Very frustrating...
sniper
Very frustrating...
sniper
21 Feb 2019 19:29 #203604
by adrianr
I'm sure it will soon be back to its hardworking reliable self.
21 Feb 2019 19:50 #203606
Sorry. It's just I'm irritated that I couldn't find an obvious cause for the initial problem and I'm exasperated at it having essentially being reworked entirely and still being wrong and vexed that it's taken nearly a week of my time to only get this far.
22 Feb 2019 05:46 #203645
Just for my sanity does anyone have a route map of the m13a cooling system showing what goes where and in which direction and so on? Because if the genuine thermostat doesn't fix it I'm taking the whole circuit In bits and flushing each element separately cos I'm out of options. It shouldn't be this difficult!
Time to create page: 0.209 seconds
