BigJimnyMeet 2024
× A place for general chat about the Jimny. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Re:2019 Jimny Australian special upgrade, or not?
22 Jan 2019 12:39 #201411 by saxj
cyberdriver wrote: G'day!
My local dealer is fitting its only demo Jimny (an auto) with a 50mm lift, wider (6") steel rims and 235/75R15 AT tyres before the official launch in Australia because they reckon this will be a popular (and legal) combo - and are offering the same to customers of either manual/auto. Apparently it's recommended/endorsed by Suzuki Aus, and no other mods are required (e.g. trimming wheel arches, lengthening cables, reducing gear ratios).
Is this the sweet spot for a mild upgrade? I can obviously test drive it, but not off-road. Before learning of this option I was thinking of just 215/75R15 ATs on the OEM alloy rims. I'll be doing some beach driving and sandy tracks/dunes but nothing too extreme - in a manual.
Where do you think I should start?
Cheers.
I have the Auto, and upped the tyre size to 215/80R15. It goes well enough, but the fuel consumption sucks.
The new Jimny is as light as the old one, so no need for huge tyres in sand. Just learn to deflate the tyres properly.
The following user(s) said Thank You: cyberdriver
22 Jan 2019 12:42 #201412 by saxj
Lambert wrote: With the 235 its a 6pc increase in height or approximately 50mm ish plus an extra 40mm width. I'd be surprised if they didn't catch somewhere on full lock full compression?
235's at stock height do rub. I'm not sure if you lift it, you'll probably need to extend bump stops. My 215/80R15's touch the inner wells at full compression.
  • cyberdriver
  • Visitor
  • Visitor
23 Jan 2019 08:24 #201487 by cyberdriver
Replied by cyberdriver on topic 2019 Jimny Australian special upgrade, or not?
Sax, you are talking about the 2019 model in those 2 replies, right?
I found a detailed article which makes a lot of sense and seems to confirm your advice sax, zukebob and lambert: outbackjoe.com/macho-divertissement/mach...s-dont-help-in-sand/
23 Jan 2019 10:44 #201501 by saxj
cyberdriver wrote: Sax, you are talking about the 2019 model in those 2 replies, right?
Yes.
23 Jan 2019 23:03 #201580 by saxj
Cheers.
I just fitted my 50mm lift tonight. It needs some work, not just a straight install. Brake lines front and back are too short. Vacuum hoses are too short. ABS wires are too short. The prop touches the front cross member.
27 Jan 2019 09:49 #201816 by Bill Portland
I see that the reversing camera is standard
Time to create page: 0.126 seconds
Powered by Kunena Forum
