BigJimnyMeet 2024
Spark plugs
- Cremator1
- Visitor
31 Dec 2018 16:08 - 31 Dec 2018 16:12 #199785
by Cremator1
Replied by Cremator1 on topic Spark plugs
Hi guys ah that’s great yep got it thank you for your time and effort with this it’s not come yet but I think I no how to do it happy new year to you and thank you xxxx
Last edit: 31 Dec 2018 16:12 by Cremator1.
- Max Headroom
- Banned
- Thank you received: 217
01 Jan 2019 11:09 #199813
by Max Headroom
Replied by Max Headroom on topic Spark plugs
Well-done Jack - that's all good belt 'n braces stuff!
Painted witness-marks are a very good old-fashioned indicator still used in modern aerospace engineering. Paint-pens... endless uses for those things!
My only worry now is that you have failed to wirelock them
I see so many photos of peoples vintage car restorations some of which reveal some dangerous omissions (split-pins the most common), so I'm never afraid to mention stuff like that - you never know it might save someones bacon one day.
The following user(s) said Thank You: jackonlyjack
- Cremator1
- Visitor
01 Jan 2019 11:11 #199814
by Cremator1
What’s wire lock do I need to do that to my damper
- Max Headroom
- Banned
01 Jan 2019 11:17 #199815
by Max Headroom
LOL no - dont worry. Wirelocking is just another method of locking nuts and bolts widely used in motor racing and aviation since the beginning of time.
WIRELOCKING INFO
WIRELOCKING INFO
- Cremator1
- Visitor
01 Jan 2019 11:30 #199816
by Cremator1
Ah ok thank you dawn
- Cremator1
- Visitor
04 Jan 2019 09:29 #199994
by Cremator1
Ok so fitted steering damper how tight do tighten the 2 nuts they attache the damper to the brackets all seems ok but there is a slight grouch sounds like the rubbers on the damper when I go to full lock
- Cremator1
- Visitor
04 Jan 2019 09:32 - 04 Jan 2019 09:32 #199995
by Cremator1
Last edit: 04 Jan 2019 09:32 by Cremator1.
- Thank you received: 551
04 Jan 2019 12:12 #199997
by Scimike
Replied by Scimike on topic Spark plugs
I just took any free play out of the damper rubber mounts by hand then locked it off with the lock nuts (second nut). It looks OK so long as you are not hitting the damper limit on full lock. As the damper moves you may hear a "squeezed liquid" type sound, its the oil in the damper moving around. Been for a drive yet, what do you think of it?
- Cremator1
- Visitor
04 Jan 2019 12:22 #199998
by Cremator1
Hi ya yes been for a drive feels good what do you mean by hitting damper limit maybe I have tightened the damper rubber nuts up to tight tighten them quite a bit
04 Jan 2019 12:47 #200001
by Scimike
The damper can only physically move from fully open to fully closed, at each end of these extremes it will stop moving, these are the damper limits to which I refer. When you fitted the damper it should have been in the middle its movement stroke, i.e in the middle of these two end limits.
With your steer straight ahead and the damper in the middle of its movement stroke, fitting it should allow your steering to move fully left / right without reaching these damper limits.
You can check you got this correct by undoing a damper mounting bolt with the steering at full lock, you should still have a little damper travel left in the same direction to which it was travelling.
Hope this makes sense.
- Thank you received: 651
04 Jan 2019 16:24 #200010
Replied by jackonlyjack on topic Spark plugs
That looks fine where it is
Mine makes the rubber rumbling groaning noise lol
You will notice less ounce your into any journey
- Cremator1
- Visitor
04 Jan 2019 20:06 #200023
by Cremator1
Hi. Guys yes makes full sense now thank for your help xx
Time to create page: 0.273 seconds
