BigJimnyMeet 2024
× A place for general chat about the Jimny. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Spark plugs
  • Mattch5150
  • Visitor
  • Visitor
29 Dec 2018 16:53 #199653 by Mattch5150
Replied by Mattch5150 on topic Spark plugs
It is a worry, most come gapped at one mm. If not right car wont start or will run bad anyway
  • Cremator1
  • Visitor
  • Visitor
29 Dec 2018 16:56 #199654 by Cremator1
Replied by Cremator1 on topic Spark plugs
Well these look bigger than a 1 mm gap
  • Mattch5150
  • Visitor
  • Visitor
29 Dec 2018 16:57 #199655 by Mattch5150
If worried go to halfords and buy their silver spark plug gap tool. Gap sensors look like claws, it's about 5.99. Don't buy the cheap one it's only for below 1mm gaps. Has gap adjuster plates on it too
  • Cremator1
  • Visitor
  • Visitor
29 Dec 2018 16:58 #199656 by Cremator1
I have a set of feeler gauges but not sure how to use them I did post pic of them
29 Dec 2018 17:00 #199657 by Busta
Replied by Busta on topic Spark plugs
If you don't have the ability to measure them yourself it's clearly best to leave them alone. It's not a critical tolerance; they will work just fine as they come in the box.
  • Mattch5150
  • Visitor
  • Visitor
29 Dec 2018 17:00 #199658 by Mattch5150
You just need to ckmbine them together so they are 1mn thick. Then slide them in the gap. It should fit in without wobble, however it's not life or death, if it is slightly loose then it should be fine
  • Cremator1
  • Visitor
  • Visitor
29 Dec 2018 17:01 - 29 Dec 2018 17:02 #199659 by Cremator1
Yes but need to learn please thank you dawn so in the pic of my feeler gauges what adds up to 1mm
Last edit: 29 Dec 2018 17:02 by Cremator1.
  • Mattch5150
  • Visitor
  • Visitor
29 Dec 2018 17:01 #199660 by Mattch5150
As busta said they should be fine as long as they are the right ones for the car
  • Mattch5150
  • Visitor
  • Visitor
29 Dec 2018 17:04 #199661 by Mattch5150
You are doing well Dawn, I'm no master mechanic either. A small plastic ruler is about a mm thick on its edge. Try that also, but plugs should be fine as each model of car those plugs are designed for will have same or similar gaps
  • Cremator1
  • Visitor
  • Visitor
29 Dec 2018 17:14 #199663 by Cremator1
Hi thank you just want to learn how to use the feeler gauge I have x
29 Dec 2018 17:27 - 29 Dec 2018 17:27 #199664 by Busta
Cremator1 wrote: Hi thank you just want to learn how to use the feeler gauge I have x
Is there not one with 1.0mm written on it? Otherwise, add together numbers that add up to 1. E.g. 0.8+0.2, 0.7+0.3, 0.53+0.47 etc. On your specific feeler gauges, use the lower 'mm' numbers. The upper number is the thickness in thousandths of an inch.
Last edit: 29 Dec 2018 17:27 by Busta.
  • Cremator1
  • Visitor
  • Visitor
29 Dec 2018 17:29 #199665 by Cremator1
No 1mm on it
Time to create page: 0.132 seconds
Powered by Kunena Forum
