Spark plugs
- Cremator1
- Visitor
- Thank you received: 1759
If each blades 0.2mm ? you need 5 in a stack for 1mm which is minimum plug gap. You shouldn't then be able to get a 6th blade into the gap as that would be 1.2mm and bigger than the upper limit.
Normally the blades are not all the same thickness though?
- Cremator1
- Visitor
- Cremator1
- Visitor
- Mattch5150
- Visitor
Cremator1 wrote: This is them
Yeah that's better. Using the mm numbers create a stack that gives you a total of 1mm then repeat but with a stack of a total of 1.1mm for each plug they shouldn't be too tight for the 1mm or slack enough for the 1.1mm to rattle about in the gap.
- Cremator1
- Visitor
- Thank you received: 14
Cremator1 wrote: Ok so use a 0.05mm and 0.04mm
No, the stacks need to add up to 1mm and 1.1mm.
Assuming you have the necessary blades there, then use the 0.4mm 0.5mm and 0.6mm
Colin
- Cremator1
- Visitor
- Cremator1
- Visitor
- Cremator1
- Visitor
