BigJimnyMeet 2024
Stuck in 4wd
- Max Headroom
- Banned
- Thank you received: 217
28 Dec 2018 19:36 - 28 Dec 2018 19:39 #199583
by Max Headroom
Replied by Max Headroom on topic Re:Stuck in 4wd
Fantastic that you found that to be 'just' a wiring snag - how much was that to get fixed?
Could the ful leak be linked to the stuttering that you describe?
Where exactly does the leak appear to be?
Last edit: 28 Dec 2018 19:39 by Max Headroom.
- Mattch5150
- Visitor
28 Dec 2018 19:42 #199585
by Mattch5150
Replied by Mattch5150 on topic Re:Stuck in 4wd
I don't know but we are running out of trial and error ideas. It's the most unreliable car I've ever had, and in the last 25 years I've owned about 23 at least. Cant carry on at this rate it's a joke.. it literally is money for nothing. May fix what we can and sell it for almost nothing as that's all its worth
- Mattch5150
- Visitor
28 Dec 2018 19:44 #199586
by Mattch5150
When tank is full it leaks in front if the rest wheel, tank side, when not full it does not leak
- Mattch5150
- Visitor
28 Dec 2018 19:51 #199587
by Mattch5150
The problem I have is there are so many problems, it could be this it could be that the moment one problem is solved or even not ,another one appears. The car is a hulk of rust, and engine, suspension problems. I know it's 13 years old but it cannott and it's design hardly be seen as reliable and strong. As it stands my partner can sell it for maybe £1000, if that. We need something more than a standard car as we live in the middle of nowhere. I grant that it is no one's fault on here, but the reliability claims do not seem to stack up, not in engine, nor suspension or pretty much any other area, even fuel tank. Sorry to be so negative but its really diffhcult not to be!
- Mattch5150
- Visitor
28 Dec 2018 19:53 #199589
by Mattch5150
And sorry for all spelling mistakes
- Max Headroom
- Banned
28 Dec 2018 20:20 #199592
by Max Headroom
After a run, and removing the fuel filler cap, do you hear a hiss of air pressure as the cap is removed or is it totally silent?
- Thank you received: 551
29 Dec 2018 08:12 #199604
by Scimike
Replied by Scimike on topic Re:Stuck in 4wd
Still stand by my original comment that it sounds like your love for this vehicle has gone and you should sell it and get something else. Its a car, they will go wrong, if you hate it every fault will just wind you up further.
Plenty of good modern vehicles to choose from, but avoid Land Rover and small TDIed engine VWs (I owned both, very expensive to fix).
RAV 4s pre 2000 have a reasonable reliability record, may even be better on rust issues, so possible cheap secondhand option. Newish maybe VW Yeti in 4x4 option?
You need to decide whats best for you and your circumstances , as you say you cant keep throwing money at a rusty unreliable Jimny if that is the case.
Good luck whatever you decide, but I hope you keep it.
- Mattch5150
- Visitor
29 Dec 2018 08:27 #199606
by Mattch5150
It is silent, no hiss
- Thank you received: 650
29 Dec 2018 11:32 #199618
Replied by jackonlyjack on topic Re:Stuck in 4wd
Fuel leak could be the hose connection from the flap
under the rear arch is a plastic cover pop the clips off and take a look
- Mattch5150
- Visitor
29 Dec 2018 15:10 #199637
by Mattch5150
Took flap off, I think it is leaking where the pipe comes out of the tank, the pipe with the large jubilee clip on. Plastic studs on flap were toast so cable tied it Back on!. Only leaks when full
- Mattch5150
- Visitor
29 Dec 2018 15:47 #199639
by Mattch5150
Replied by Mattch5150 on topic Stuck in 4wd
Put new spark plugs i
in today, just bosch nickel ones. The plugs that were in were all in very loose, almost not screwed in at all. 3 plugs the same and one different. Running fine at the moment and my stutter seems to have gone. Btw have posted a pic of the offending jimny as don't think I have before!
29 Dec 2018 17:52 #199667
by Busta
Replied by Busta on topic Stuck in 4wd
Sounds to me like you've just been very unlucky and bought Britain's worst kept Jimny!
I've never heard of the fuel leak issue before, nor broken wires to the transfer case. If the front wheel bearings were gone that would be another cause of the front hubs not working.
Loose spark plugs is entirely the fault of the person that fitted them, again not a reliability issue with the Jimny.
