BigJimnyMeet 2024
× A place for general chat about the Jimny. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Stuck in 4wd
  • Mattch5150
  • Visitor
  • Visitor
16 Dec 2018 15:55 #199058 by Mattch5150
Replied by Mattch5150 on topic Stuck in 4wd
I have joined the rubber hose and braided hose with a plastic t piece. No joy, light still flashing and stuck in 4wd. Am stuck now!
16 Dec 2018 16:03 #199060 by jackonlyjack
Replied by jackonlyjack on topic Stuck in 4wd
I think theirs a filter just below battery should be a blue colour
you may have sucked crap up and blocked it just a thought
  • Mattch5150
  • Visitor
  • Visitor
16 Dec 2018 16:10 #199061 by Mattch5150
I washed that yesterday the tiny little sponge one
?. The pipe s had a metal connector in between them I cut the end of each tube to get it out. Hollow plastic tube in now which is tight. Is the large blue plastic thing a filter too. Btw thanks so much for everyone's help you have all been amazing.
  • Mattch5150
  • Visitor
  • Visitor
16 Dec 2018 16:27 #199063 by Mattch5150
Just a big thanks to all that have helped me. I'm still struggling but at least appear to have found the fault. All I can presume is there is either another split pipe somewhere or a blockage. My plastic t piece to join both tubes seems good but I'm still stuck in 4wd. Is there any way I could drive to the garage even slowly and without turning too tight. Also if I use a syringe on the separated tube would that unlock the hubs. I'm a nurse so have access to some good syringes. Despite my fears last night I do live the jimny, I've done lots on it but this has stumped me. If a garage has a vacuum tester would that help?. Thanks again you are all awesome!
16 Dec 2018 16:32 #199065 by mlines
Replied by mlines on topic Re:Stuck in 4wd
Its a bit confusing reading your problems. Vacuum issues usually mean it will not go into 4wd. For it to be stuck in 4wd usually points to the transfer box on a vvt Jimny.
However if it is the hubs locked on then simply unbolt them and remove them. You can then drive to the garage
  • Mattch5150
  • Visitor
  • Visitor
16 Dec 2018 16:36 #199066 by Mattch5150
Replied by Mattch5150 on topic Re:Stuck in 4wd
Ok that's good to know. The black hubs with the hex bolts ? You mean.
Thanks
  • Mattch5150
  • Visitor
  • Visitor
16 Dec 2018 16:51 #199068 by Mattch5150
I've just lay down outside whilst the gf drives car forward. Front prop shaft is definately turning
16 Dec 2018 17:07 #199071 by Jezz
Replied by Jezz on topic Stuck in 4wd
The black bits.
It's been fettled just a tad.
  • Mattch5150
  • Visitor
  • Visitor
16 Dec 2018 17:09 #199072 by Mattch5150
Lol you all must think I'm thick as anything. I will have to get some hex sockets as have none lol!
16 Dec 2018 17:18 #199074 by Max Headroom
Replied by Max Headroom on topic Stuck in 4wd
Mattch5150 wrote: Lol you all must think I'm thick as anything. I will have to get some hex sockets as have none lol!
It's frustrating as I'm not far from you but stuck at work - had this been during my 'off' shift I could have come along and helped out - I've got a small selection of metric tools that would have covered the job.
Let me tell you I could not do the job of a nurse - I can imagine the "shoe on the other foot" and you trying to help me through some horrendous medical procedure I'd be really stuck; out of my depth and in need of a change of underwear!
I take my hat off to you for having the tenacity to try and sort it out on your own. [smiley thumbs up needed here]
  • Mattch5150
  • Visitor
  • Visitor
16 Dec 2018 17:26 #199075 by Mattch5150
Yes I just do surgical nursing now but was a specialist in Intensive care for 15 years and a transplant coordinator speaking to families of deceased and getting organs. It made me Ill with stress eventually. I love mechanics. This us just so frustrating. I will drive to garage tomorrow in my nice honda civic . I will ask if i can borriw his hex keys and then get it down there. I really thought once joining tubes up it would fix it but no!!
16 Dec 2018 17:37 - 16 Dec 2018 17:38 #199076 by Jezz
This is the confusing thing. The vacuum is used to pull the hubs in to lock them. If you have a split hose in the vacuum system the hubs would not lock as it would suck the air from atmosphere via the break/split hose. So in theory they should not be locked. Just as a side note, It does have vacuum hubs and not manual??
Last edit: 16 Dec 2018 17:38 by Jezz. Reason: spelling
Time to create page: 0.136 seconds
Powered by Kunena Forum
