BigJimnyMeet 2024
Stuck in 4wd
- Thank you received: 650
16 Dec 2018 10:49 #199038
Replied by jackonlyjack on topic Re:Stuck in 4wd
The prop has splines on it if you pick it up by one end it will slide apart
Its balanced so its important to keep it together ( that's why i say draw a line down it )
so if it separates you can mach up the line and not rotate it out of balance
- Mattch5150
- Visitor
16 Dec 2018 10:53 #199039
by Mattch5150
Replied by Mattch5150 on topic Re:Stuck in 4wd
Forgive my thickness. I've changed radiator and belts etc on it but this is new to me. If I unbolt the shaft at each end I then need to knock it forward away fromtransfer box. Are the spines on each end of the shaft itself. Can the whole long shaft split apart. . Thanks so much for your patience!!
Matt
Matt
16 Dec 2018 12:52 #199044
When all the 8 bolts are removed the prop shaft will be stuck in position
i use an old wood chisel to split it from diff and transfer flange
you could use a flat screw driver or just tap it with a big hammer
then just pull it out
- Max Headroom
- Banned
- Thank you received: 217
16 Dec 2018 13:50 - 16 Dec 2018 13:50 #199048
by Max Headroom
Replied by Max Headroom on topic Re:Stuck in 4wd
Unfortunately, although I'm not all that far from you, I'm stuck on work shifts for over 12 hours at a time or I could have popped up to give you a hand
Last edit: 16 Dec 2018 13:50 by Max Headroom.
- Mattch5150
- Visitor
16 Dec 2018 13:55 #199049
by Mattch5150
No worries under car now bolts very tight and shaft flexing is that ok to keep forcing it?
16 Dec 2018 13:57 - 16 Dec 2018 13:58 #199050
by Jezz
The prop has eight bolts, Four at each end, (black circles). With the bolts removed, if the prop doesen't fall off, Just gently tap one end or the other with a soft hammer or mallet and it will come loose.
The red circle is the splined joint. Try not to seperate it there.
It's been fettled just a tad.
Replied by Jezz on topic Stuck in 4wd
Last edit: 16 Dec 2018 13:58 by Jezz. Reason: spelling
- Mattch5150
- Visitor
16 Dec 2018 14:00 #199051
by Mattch5150
Replied by Mattch5150 on topic Stuck in 4wd
Awesome thanks so much for that. As above I'm under car now. Bolts very tight. Shaft seems to flex as informing. Is it ok to keep forcing them?
16 Dec 2018 14:04 #199052
by Jezz
Yeah, The bolts will be locktighted on. Make sure your spanner/socket is a good fit and lean on them, They will give in the end.
- Mattch5150
- Visitor
16 Dec 2018 14:09 #199053
by Mattch5150
The end of the diff is flexing feels like it would snap if I pull any harder. Does it have to be in gear or anything
16 Dec 2018 14:12 #199054
by Jezz
Yes, Hand brake on and i normally but mine in reverse gear.
- Mattch5150
- Visitor
16 Dec 2018 15:03 #199055
by Mattch5150
After all this. Under car and saw a split pipe. It is the braided one on passenger wheel. Metaljoin tube is rotten.. I'm now try I g to find a hollow tube to join it but no luck so far!!
- Thank you received: 1755
16 Dec 2018 15:47 #199056
Replied by Lambert on topic Stuck in 4wd
Good luck!
Time to create page: 0.242 seconds
