BigJimnyMeet 2024
Light wiring
- Mole
- Visitor
25 Nov 2018 16:27 #198144
by Mole
Light wiring was created by Mole
Evening.
Now I not sure if it's me being a bit dumb iv gone to wire my front spots up to day and want them to work with high beam. I have usually just spurred off the main beam wire as a trigger for the relay But when I put a meter on the plug that goes to the bulb all 3 pins have 12volts but the build dosent light untill turned on in the cab. So this means I can us it as a trigger because the relay would constantly be on.
Why dose the power have 12 all the time to all 3 pins
Any help much appreciated wiring isn't my strong point
Thanks
Thanks
- paradox1001
- Visitor
25 Nov 2018 17:37 #198148
by paradox1001
Replied by paradox1001 on topic Re:Light wiring
Jimnys are permenant live with the earth switched.
- Mole
- Visitor
25 Nov 2018 17:54 #198151
by Mole
Replied by Mole on topic Light wiring
Oh OK so if I want to use the hight beam as a trigger what would be the best way to do this spur off the wire from the stork in the cab?
25 Nov 2018 18:50 #198153
Replied by mlines on topic Re:Light wiring
Wire the relay in the same way as the lights. As the lights are earth switched then connect the earth side of the relay coil to the switched feed to the lights and a permanent live to live side of the relay coil.
Think upside down to "normal" wiring
- Mole
- Visitor
25 Nov 2018 19:11 #198155
by Mole
So like this pls see pic
- Thank you received: 583
25 Nov 2018 19:25 #198157
by facade
Replied by facade on topic Light wiring
just connect pin 86 to the white wire with a coloured stripe going to the headlight. or better a fused positive supply through a switch, and pin 85 to the all red wire going to the headlight.
- Mole
- Visitor
25 Nov 2018 19:53 #198160
by Mole
So would this be the right way round? This stuff never sinks in
- Thank you received: 225
26 Nov 2018 04:36 #198165
by zukebob
Replied by zukebob on topic Light wiring
As Facade said. The white and colored stripe to pin 86 and the solid red (high beam) wire to 85. That provides current, exciting the relay (switching it) when the high beam is on. Assuming there is no pin 87a, connect your fused lead from the battery to pin 30 and your spot light lead to pin 87. Run the ground from your spots to an appropriate ground.
- Mole
- Visitor
26 Nov 2018 06:21 #198167
by Mole
Ok thanks will try that thanks all for your patience
26 Nov 2018 10:08 #198171
by zukebob
No patience required. We all try to help. Let me also clarify my post. It would be better to say that you would tie into the white and striped wire and the red wire with leads from the 86 and 85 relay pins.
Just post again if you have problems.
- Mole
- Visitor
26 Nov 2018 10:12 #198172
by Mole
Thank you will have a little time to mess with it tomorrow afternoon so will report back then Or ask for more help one or the other haha
26 Nov 2018 16:54 #198183
by kirkynut
Replied by kirkynut on topic Light wiring
The quickest way for me to answer is look here as I did it recently:
www.bigjimny.com/index.php/forum/8-my-ji...-continues?start=264
Time to create page: 0.173 seconds
