BigJimnyMeet 2024
Diff oil
- Cremator1
- Visitor
24 Nov 2018 17:23 #198105
by Cremator1
Diff oil was created by Cremator1
Hi all so got my new jimny and want to change the diff oil what’s the best brand to use many thanks dawn
- Thank you received: 651
24 Nov 2018 17:33 #198106
Replied by jackonlyjack on topic Diff oil
Two good one's here
www.opieoils.co.uk/search/go?lbc=opieoil...id&af=size%3a5litres
- Cremator1
- Visitor
24 Nov 2018 17:48 #198109
by Cremator1
Replied by Cremator1 on topic Diff oil
Hi thank u is mineral oil ok
24 Nov 2018 20:05 #198116
I have millers mineral in my diffs
Redline MT90 in gearbox
castrol semi synthetic in engine
Castrol classic in transfer box (SJ lobster box)
- Cremator1
- Visitor
25 Nov 2018 07:32 #198123
by Cremator1
Ok will go for millers in diff not sure about gear box as it is auto do not sure what to use in it
- Cremator1
- Visitor
25 Nov 2018 12:38 #198128
by Cremator1
Ok so see the auto gear box oil as to be down by a Suzuki dealer managed to undo rear diff plug but can’t undo front one not using a proper key using a ratchet handle but won’t budge should I get a proper key to remove it many thanks dawn
- Thank you received: 1759
25 Nov 2018 13:53 #198131
Yes definitely. Using it 3/8 drive is only good if it starts to undo fairly easy. The 10mm drive is a better bet if the plug is being recalcitrant.
- Cremator1
- Visitor
25 Nov 2018 13:59 #198132
by Cremator1
Hi ya ok think I need to get a set u have an auto don’t u have u ever changed the gear box oil in it
25 Nov 2018 14:17 #198135
The auto uses A/T fluid Dexron IIE
It takes about 1.1 litres but in practice, as there is no proper drain, you have to pump it out.
- Thank you received: 14
- Cremator1
- Visitor
25 Nov 2018 15:38 #198140
by Cremator1
Hi thanks for the reply’s guess I will have to take it to garage for the auto box oil change
Time to create page: 0.166 seconds
