BigJimnyMeet 2024
Passed MOT!
23 Nov 2018 14:22 #198047
Passed MOT! was created by mlines
Annual test day today, passed ok!
Few "minors"
Two bulbs, which were working last night, were dead. Swift bash sorted them.
Both rear wheel bearings have slight play (new last year, only 600 miles on-road driven, no off-road)
Panhard bushes showing slight play
Brake hose contacts body occasionally
Steering box needs slack removing.
Winch electric cables insecure (rubbing radiator mount)
So some new panhard bushes on order. Some cable tying needed on the brake hose and winch power
Leave the wheel bearings a little bit longer (after a possible off-road trip over Christmas)
Few "minors"
- Thank you received: 923
- Thank you received: 551
23 Nov 2018 15:24 #198050
by Scimike
Replied by Scimike on topic Passed MOT!
Nice to have for another 12 months.
I would forget about the rear bearings till the next mot unless you think its an issue.
MOTs advisory comments are just a way of covering the MOT testers a"se these days i.e If in any doubt put it down in writing.
Have a tiger 800 motorbike which had an advisory on the front tyre (crazing or similar) one year, next year it was square profile on rear tyre, last year it passed no advisories. Thing is its still on the same tyres and I take it to the same MOT station, figure that out
Hoping our first MOT with our Jimny will be a good one. Does not drive like anything is wrong, so looking for a 1st time pass. Jan the 7th is d day.
23 Nov 2018 15:44 #198052
Replied by mlines on topic Passed MOT!
My relationship with my MOT station is good. He tends to offer advisories on the understanding I will fix them rather than fail the car.
For the rear wheel bearing it was a "keep an eye" on them advice so thats fine.
Last year he said he didnt want to see the tyres that were on it at the time ever again. They were date stamped in 2005 and had lots of flint cuts and sidewall perishing. So it was a fair call and new boots were ordered.
- OlaGB
- Visitor
23 Nov 2018 19:38 - 23 Nov 2018 19:57 #198066
by OlaGB
Replied by OlaGB on topic Passed MOT!
I see several people struggle with rear wheel bearings..
If you used it only onroad, i really dont understand what can kill them that quickly? Any thoughts?
Last edit: 23 Nov 2018 19:57 by OlaGB.
23 Nov 2018 20:46 #198076
Replied by mlines on topic Re:Passed MOT!
32" wheels
- OlaGB
- Visitor
24 Nov 2018 07:25 #198088
by OlaGB
Replied by OlaGB on topic Re:Passed MOT!
So wheel weight, is youre take on it then i guess?
Diameter shouldnt do any change, but weight and high negative offset would increase bearing load some.
Then again, alot of patrol and Jeep guys run 38-42" without any huge bearing issues.
Only 600 miles is absurd, and atleast 50 times less than i would expect from any car.
I would expect 600miles hard offroading from a new bearing, if you pack the outside with grease to seal it some.
Has to be more than just wheel dimension causing this?!
24 Nov 2018 08:01 #198089
Thing is, the bearing is small. Jeep ones are probably tougher
- paradox1001
- Visitor
24 Nov 2018 12:22 #198093
by paradox1001
Replied by paradox1001 on topic Re:Passed MOT!
Some bearings nowadays are shocking quality and there’s even fakes knocking about.
24 Nov 2018 13:22 - 24 Nov 2018 13:23 #198096
These are premium quality, just pushed to extremes
Last edit: 24 Nov 2018 13:23 by mlines.
- OlaGB
- Visitor
24 Nov 2018 14:50 #198099
by OlaGB
32" wheels onroad, is not even close to what i would call pushed to extreme.
600 miles is a month of driving for most of us, even with 32" wheels i would expect 20-30k miles onroad.
I`m suprised you accept this as normal.
It sure will keep me away from bigger than 29" wheels if i must expect changing bearings 8-12 times a year.
24 Nov 2018 16:35 #198101
Replied by X8GGY on topic Re:Passed MOT!
I've just looked back at my build thread on this very fine forum...
I last fitted all new bearings in mid-May this year, since then we've done -
A day's laning in North Wales at the end of May
A weekend's laning in the Lake District in Mid July (there and back and around and around)
Another day's laning in North Wales again in August
Another weekend's laning in the Northumberland in early September (there and back and around and around)
In September the MOT pulled up an oil leak rear nearside but that was found to be an ill-fitted oil seal
A day trip laning in the Lake District in early October (there and back and around and around)
Another day's laning in North Wales again in mid November
That must be well over 600 miles, and some nice rough gnarly greelaning to boot...?
Time to create page: 0.168 seconds
