BigJimny Meet 2019 (17 May 2019)
BigJimny Meet and off-road driving day
20TH OCTOBER 2019
BOOK NOW (BOOKING CLOSES EARLY OCTOBER!!) - CLICK HERE
See HERE for details - See HERE for discussion
Noggin and Natter - pre-event chat - Old Bell at Grazeley (part of hotel) 7:30pm 19th October
× A place for general chat about the Jimny. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
logo.[/size][/color][/b]
Abs light diagnostic
08 Nov 2018 18:46 #197477 by Johntom
Replied by Johntom on topic Abs light diagnostic
Found the tests below for dtc061, number 3 gives 0.5 ohms not open circuit.
09 Nov 2018 14:22 #197523 by Johntom
Tried all over to get a used Denso abs pump, don’t suppose anyone on here has one for sale ?
09 Nov 2018 20:50 - 09 Nov 2018 20:52 #197532 by Delux
Replied by Delux on topic Abs light diagnostic
Had a look at that page in the manual, number 3 is basically Suzuki manual speak for 'I dont know'!
Looking at the schematic, you are basically testing for resistance between the positive side of the motor (A23) and earth (which is connected to A22). In effect you are measuring the resistance of the pump motor, an electric motor. The motors resistance will change depending on its position.
The code is stating the motor has failed. So if you power it up it wont work, right? With the control unit disconnected why not carefully connect an earth wire to A22 terminal and a live to A23? If the motor operates you know the fault is with the ABS controller connection at the control unit. If the motor doesnt work try giving it a firm whack with a big screwdriver handle a few times then try it again.
Please do not treat the manual as set in stone. Workshop manuals are generally written by non mechanics to repair faults that havent actually happened in the real world.
Just for arguments sake, lets assume the problem is with the terminal in the plug at A23. If you replace the ABS control unit, the fault is still going to be there but you wont find out until you have messed about fitting the unit, bled the brakes and cleared the codes!
COOL JIMNY FOR SALE! HERE!
Last edit: 09 Nov 2018 20:52 by Delux.
  • Max Headroom
  • Max Headroom's Avatar
  • Online
  • Site Sponsor
  • Site Sponsor
  • OPEN AIR MOTORING... 93 MILLION MILES OF HEADROOM
10 Nov 2018 05:09 - 10 Nov 2018 05:10 #197538 by Max Headroom
Replied by Max Headroom on topic Abs light diagnostic
Tell me about it!
As an aircraft engineer, I firmly believe we are only there to find all the mistakes in the manuals as well as fix the dreadful design-faults :angry: :evil:
Last edit: 10 Nov 2018 05:10 by Max Headroom.
The following user(s) said Thank You: Delux
10 Nov 2018 11:04 - 10 Nov 2018 16:15 #197544 by Johntom
Hi
I have just given the motor a tap and then I was able to reset the abs code and extinguish the warning light. I drove the car about 2 miles with the light off, however it did come back on with the same code.
I removed the control unit and ran earth/12v to the 2 exposed motor pins and the motor turned ?
Only got continuity through pump pin 22 of the control unit to the female terminal that meets the pump male connection, no continuity between the terminal 23 and the other female.
Again I tried to reset the code but it only worked after tapping the motor?
Also is it possible to remove the motor (just 2 screws) without disturbing the brake fluid ?
Last edit: 10 Nov 2018 16:15 by Johntom.
14 Nov 2018 10:13 #197652 by Johntom
Hi
If I remove the motor from the abs unit will I loose the brake fluid or is the valve unit sealed from the motor as it is from the module ?
Moderators: funkyjimnyooky_123
Time to create page: 0.083 seconds
Powered by Kunena Forum
