BigJimnyMeet 2024
Sensors
- Basketcase
- Thank you received: 51
01 Nov 2018 19:12 #197233
by Basketcase
Sensors was created by Basketcase
Had the Jimny on the diag box at work today doing a live test. The o2 sensor voltage was fluctuations from 0.200v to 0.900v rather erratically. Is this normal or does it need a new sensor? Its running ok but rich the box said it was running rich then lean but flicked back to rich and seemed to stay as rich more than lean. Any ideas would be fantastic!!
05 Nov 2018 20:27 #197351
by Delux
Busiest Mechanic in Scotland!
My pics (inc. pics of my latest Jimny project)...
www.flickr.com/photos/159422664@N08/albums
My ebay stuff for sale...
www.ebay.co.uk/usr/deeelux
This is normal. The ECU is monitoring the amount of unburnt fuel so the voltage switches back and forth. 0.2v is lean, 0.8 is rich.
In my experience the heater circuit burns out inside the sensor and sets a fault code long before the sensor its self fails. Either way you would get a fault code eventually.
I say that because the ECU has to see a pattern before it will throw up a fault code. With O2 sensors, the car has to have performed a readiness test 1st. That involves the ECU watching the sensor readings while the car starts, gets to normal operating temp, is switched off then started again.
- JustCallMeRick
- Visitor
05 Nov 2018 20:58 #197353
by JustCallMeRick
Replied by JustCallMeRick on topic Sensors
thats normal when the engine is idling and at part throtle(closed loop).
the ecu does that to get maximum efficiency from the catalytic converter.
there is some science/chemical wizardry involved which i have forgotten:laugh: .
- Basketcase
06 Nov 2018 09:17 #197382
by Basketcase
Replied by Basketcase on topic Sensors
Haha I need to find the scientist/wizard then....I guess the sensor is t the reason the car is running rich then is it... any ideas what I should try to get it to not run rich?
06 Nov 2018 17:22 #197399
by Delux
If the sensor is switching between rich and lean, the ECU thinks it is running ok. What makes you think it is running rich?
- Basketcase
06 Nov 2018 18:01 #197400
by Basketcase
It smells really rich and did 150 miles on a tank and the lambda emissions aren’t right. It’s defo not running 100% atm
06 Nov 2018 21:03 #197405
by Delux
Is the lambda too high or too low?
- Basketcase
06 Nov 2018 21:12 #197406
by Basketcase
I’m pretty sure it was miles too high but can’t remember now everything else was in perfect though after a dose of lambda cleaner
06 Nov 2018 23:13 #197409
by Delux
Trying not to lose myself in getting too technical here!
Lambda, as measured by an emissions tester is a measurement of the amount of oxygen in the exhaust gas.
If all is ok and the fuel mixture is 14.7 to 1. Its the ideal mixture, known as the stoichiometric point (might want to check the spelling there, LOL!). Its what the ECU is constantly trying to achieve based on input from its sensors. When you see the O2 sensor flick from rich to lean to rich etc. that is it feeding back the actual, instant amount of oxygen in the exhaust gas trying to keep the engine running as close to that point as it can.
The point that the engine achieves this is called Lambda. When the stoichiometric point is acheived Lambda should be 1.
If your engine is running lean the air/fuel ratio will be higher, more bits of air per bit of fuel being burned. As a result the emissions tester would show the Lambda to be too high. Your O2 sensor shows rich, meaning it wants the ECU to enrichen the air/fuel ratio.
Lean mixture could be caused by a dodgy sensor or air/exhaust leak. If it improved after cleaning it with lambda cleaner it could be a sensor, then again, you may have just cleaned the carbon off it that has built up with the ECU trying to compensate for an air leak.
- Basketcase
07 Nov 2018 22:45 #197443
by Basketcase
When I got the car the centre pipe of the exhaust was knackered so changed that and now the back box is blowing slightly but I guess that wouldn’t cause the rich smell would it? Would a good service help? Don’t know when it had new plugs or even an oil change but would that actually make much of any difference? Could it be one of the coils not working properly? It’s not midfiring (or doesn’t seem like it). The car does feel underpopwered compared to the m13 engine but again I don’t know if that’s normal or not.
- Thank you received: 584
08 Nov 2018 18:26 #197476
by facade
An exhaust leak will cause a high lambda, because oxygen gets into the exhaust gases.
The rich mixture will cause high HC- but that is an over simplification, as a lean mixture can cause high HC too due to lean missfires.
High HC plus high lambda (with no exhaust leak) indicates an over lean condition.
High HC plus low lambda indicates over rich.
A missfire due to dirty plugs would cause high HC and the lambda would be 1.000 I reckon.
The usual failure mode of the pre-cat sensor is to switching at an over-rich mixture, which won't put the EML on until it runs out of rich fuel trim and still can't close the loop.
I would suspect you need a new pre-cat sensor to improve the mpg, and to fix the exhaust leak if you want to pass the MOT. (I don't know why lambda is in the MOT, but it is)
- Basketcase
08 Nov 2018 22:14 #197506
by Basketcase
Right so a service wouldn’t make a great deal of difference here then. Should I just throw a ew pre cat sensor in and see if it makes any difference? Is that what you’d do? I know there’s a few different sensors available for the Jimny engines ranging from £17 to £79 ( trade prices) how do I find which one is the right one? Should the like is euro know which one it is? Or should I get a generic one with the same number of wires? Don’t want to be wasting any money atm as I’m starting a new job soon so this payday will be a very small one but will need the car to be running better to get me there more economically....well cheaper really lol
Time to create page: 0.178 seconds
